[Mapserver-dev] Label centroid alog
Vincent Schut
schut at sarvision.com
Tue May 13 06:47:35 EDT 2003
Hello dear developers,
you might have noticed my label problem posted on the users list
(http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0305/msg00016.html).
I just tried this patch and it solves my problem. Thought I'd just let you
know that...
Could (or is this already?) this be applied to cvs? To me it really is a
bug-fix :-) Thanks!
Regards,
Vincent Schut.
On Monday 05 May 2003 23:06, John Newton wrote:
> The labeling centroid algorithm has sometime given me incorrect results and
> I believe I see the reason why. The point1 and point2 pointers can
> sometimes point to the same object, thereby rendering incorrect length
> calculations (namely zero length).
> Here is my suggested change to the code. Basically I remove the use of
> point1 and point2 for determining length and max_len, and get the length
> using the diff in x, not length(), since the y values are equal.
> -john
> --- \mapserver\mapserver-3.7-dev\mapprimitive.c 2003-02-26
> 12:18:22.000000000 -0800
> +++ mapprimitive.c 2003-05-05 13:41:44.000000000 -0700
> @@ -950,16 +923,13 @@
> } while(wrong_order);
> /* Great, now find longest span */
> - point1->y = point2->y = y;
> - for(i=0; i < nfound; i += 2) {
> - point1->x = xintersect[i];
> - point2->x = xintersect[i+1];
> - len = length(*point1, *point2);
> + for(i=0; i < nfound; i +=2) {
> + len = fabs(xintersect[i] - xintersect[i+1]);
> if(len > max_len) {
> max_len = len;
> - lp->x = (point1->x + point2->x)/2;
> + lp->x = (xintersect[i] + xintersect[i+1])/2;
> lp->y = y;
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
