[Mapserver-dev] How to Show chinese characters?
keni
keninet at sina.com
Tue May 20 01:08:45 EDT 2003
Steve Lime,hello!
The UNICODE encoding include unicode utf-16 encoding,unicode uft-8 encoding and unicode
utf-7 encoding,which is the "UNICODE".
The font which i use supports UNICODE,and the font's name is "Arial Unicode MS".chinese characters with utf-8 encoding are sucess to show,other encoding are wrong to show.
Thanks you very much for your informations!
======= 2003-05-19 19:32:00 ÄúÔÚÀ´ÐÅÖÐдµÀ£º=======
>The new versions of GD have support for more character mappings which may help you, but as long as the fonts you're using support UNICODE you should be fine. Note that you MUST use TrueType fonts. The GD bitmap fonts support only a limited character set. I've forwarded this to the main list in hopes they may help. I know this question has been asked before...
>Steve
>Stephen Lime
>Data & Applications Manager
>Minnesota DNR
>500 Lafayette Road
>St. Paul, MN 55155
>651-297-2937
>>>> "keni" <keninet at sina.com> 05/18/03 10:10 PM >>>
>mapserver-dev, hello$)A#!
> I am a student and want to use Mapserver to build the web map station.But i download both
>mapserver 3.6 and mapserver 3.7,it cannot show the chinese characters in the label and the
>legend.
>thanks
>$)A!!!!!!!!!!!!!!!!keni
>$)A!!!!!!!!!!!!!!!!keninet at sina.com
>$)A!!!!!!!!!!!!!!!!!!!!2003-05-19
>_______________________________________________
>Mapserver-dev mailing list
>Mapserver-dev at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡ÖÂ
Àñ£¡
¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡keni
¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡keninet at sina.com
¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡¡2003-05-20
