[Mapserver-dev] Re: [Mapserver-users] Mapscript drawQuery() on big PostGIS layers doesn't work properly ?
David Blasby dblasby at refractions.net
Wed Oct 15 15:23:39 EDT 2003
Paul Ramsey wrote:
>> msLayerWhichShapes() is called to initialize the query.  In the case
>> of shapefiles this means retrieving the list of shapeIds, but in the
>> case of PostGIS it could be just performing the query to the DB.  I
>> believe that's what msPOSTGISLayerWhichShapes() does today.
>> Then msLayerNextShape() is called until there are no more shapes to
>> read.  The postgis implementation of this could simply scroll through
>> the resultset that was created in msLayerWhichShapes().
It could be possible to have msLayerWhichShapes()  (a query-by-rectangle
with filter) cache the results so that msLayerGetShape( <record number>
) works quickly.
I think that mapserv doesnt call msPOSTGISWhichItems() (or sets the
items list) until *after* the  query-by-rectange, so I dont know what
columns to grab from the DB.
I dont know why there's a separate query mechanism is mapserv - why
doesnt it just call msLayerWhichShapes() then msLayerNextShape() like
the normal drawing routines?  It seems there's twice as much code to
maintain than necessary.
dave
