[Mapserver-dev] jBox image dragging
Richard Greenwood
Rich at GreenwoodMap.com
Wed Oct 29 15:40:31 EST 2003
At 11:31 AM 10/29/2003, Steve Lime wrote:
>I've don't have a distribution in place. I can add one quickly though. The
>addition of this feature is probably a good reason do to just that. I'd
>distribute
>from the same place the mapserver distribution is available and let Kari
>link to it
>from the jbox howto and the utilities pages. One question, I assume there
>is also a dragoff method?
Yes. There are 3 modes now: boxon, lineon, dragon, each with a
corresponding off function. The off functions are just synonyms for boxoff.
I've committed both the gif/jpeg version, and the png version to CVS so you
can take a look at them. (And a working example is at
www2.tetonwyo.org/mapserver)
I exchanged emails with Kari a couple weeks ago about getting jBox onto the
utilities page instead of mapplet, but she was gone for a while, and then I
was gone, so we haven't got it together yet. I'll continue to pursue that
with her unless you would prefer to.
And I still have it on my "to do" list to get a build system together in Ant.
Regards,
Rich
>Also we need to figure out how to handle formal version #'s for this. I'm
>fine with
>calling this version 1 and moving on from there. I suppose a constant
>should be set
>in the code with that value.
>Steve
> >>> Richard Greenwood <Rich at GreenwoodMap.com> 10/27/2003 10:42:25 AM
>Steve,
>Thanks for your reply. I'll commit my modification to CVS. (I had not
>wanted to commit it because I wasn't sure if negative coordinates were
>legal.) The way I have implemented dragging won't break any existing
>jBox
>or dBox stuff, it's just a new function call: dragon().
>Are you distributing dBox, and if so, where would I find it?
>Rich
>At 10:03 AM 10/27/2003 -0600, Steve Lime wrote:
> >Cool, nice modification, now of course I need to modify dbox. There
>is
> >no problem sending
> >negative coordinates. That's how most panning is done anyways.
> >Steve
> > >>> Richard Greenwood <Rich at GreenwoodMap.com> 10/26/2003 9:03:36 PM
> >I have added image dragging functionality to jBox. This allows the
>user
> >to
> >drag the image within the applet area. A new imgxy is then passed to
> >mapserver when the mouse is released. A working example is at
> >http://www2.tetonwyo.org/mapserver/
> >Depending on how far the user has dragged the image, the new values
>for
> >imgxy may be negative and/or greater than the current image size. In
>my
> >limited testing this has not generated any errors. Does anyone see a
> >problem with this? i.e. Am I breaking any rules by sending negative
> >imgxy
> >values, or imgxy values greater than the current image size?
> >Thanks,
> >Rich
> >Richard W. Greenwood, PLS
> >Greenwood Mapping, Inc.
> >Rich <at> GreenwoodMap <dot> com
> >(307) 733-0203
> >http://www.GreenwoodMap.com
> >_______________________________________________
> >Mapserver-dev mailing list
> >Mapserver-dev at lists.gis.umn.edu
> >http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
>(307) 733-0203
(307) 733-0203
