[Mapserver-dev] Adding projection object to the refernece map
Daniel Morissette
morissette at dmsolutions.ca
Wed Sep 17 10:00:38 EDT 2003
Yewondwossen Assefa wrote:
> The intention is to add a projection object to the reference map. This
> need was raised by interactive applications where the user was able to
> modify the map projection. The extents specified in the refernce map
> were then not "valid" to render properly the bbox. The intention is to
> to be able to use the projection of the map object and the one in the
> reference object to compute properly the bbox.
> If the projection object is not set It will work as it is now.
> Any comments ?
> Note : this was added as a Bugzilla enhancement request Bug 432.
There was already bug 265 about this. See the discussions in this bug:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=265
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
