[Mapserver-dev] Possible bug with outlinecolor in label for RGB outputformat
Claude Philipona
claude-mapserver at skirando.ch
Sat Sep 27 12:55:12 EDT 2003
Hello,
There is maybe a bug when OUTLINECOLOR is set with truetype label in RGB
OUTPUTFORMAT (jpeg/png24). There outline appears as "square" instaed as
"line" around the letters label.
All the where made with a simple call to a mapfile, using
Mapserver4.0/PHPMapscript. You'll find the mapfile at the end of this
message.
GD 2.0.15
Freetype 2.1.5
Gdal 1.1.9
Result with IMAGETYPE png (8bit), everything is ok, the outline is present:
http://www.camptocamp.com/~claude/mapserver/test_label_png.png
Result with IMAGETYPE png24 (24bit), no outlines, but square:
http://www.camptocamp.com/~claude/mapserver/test_label_png24.png
Result with IMAGETYPE jpeg (24bit) same as png 24 (squares instead of
outlines):
http://www.camptocamp.com/~claude/mapserver/test_label_jpg.jpg
Then I tried several configuration:
When I set POSTLABELCACHE ON and TRANSPARENCY 100 on the layer, the
OUTLINES are ok, but now (of course) label collision occurs:
http://www.camptocamp.com/~claude/mapserver/test_label__post_label_cache_transparency_100_png24.png
With POSTLABELCACHE ON or TRANSPARENCY 100 settings alone, the outlines
are not set properly either:
http://www.camptocamp.com/~claude/mapserver/test_label_transparency_100_png24.png
http://www.camptocamp.com/~claude/mapserver/test_label__post_label_cache_png24.png
This behaviour is quite annoying, because it is apperently impossible to
have nice OUTLINES in RGB formats without POSTLABELCACHE ON and
TRANSPARENCY 100, and often we don't want to use these two settings becaus
of the side effect.
Is this a know bug (I couldn't find one in bugzilla)?
Claude
NAME TEST
STATUS ON
SIZE 600 450
SYMBOLSET "symbols_1.sym"
EXTENT 532500 152180 534340 152880
UNITS METERS
SHAPEPATH "../shapes"
TRANSPARENT OFF
IMAGETYPE png24
IMAGECOLOR 210 190 190
FONTSET "etc/fonts.txt"
WEB
MINSCALE 0
MAXSCALE 40000
IMAGEPATH "/var/www/test2/htdocs/tmp/"
IMAGEURL "/test2/tmp/"
END # WEB
LAYER
NAME buildings
TYPE POLYGON
STATUS ON
DATA "buildings"
TRANSPARENCY 60
CLASS
NAME "BAT"
STYLE
COLOR 50 200 50
OUTLINECOLOR 152 227 152
SYMBOL 0
SIZE 1
END
END
END
LAYER
NAME "roads_label"
TYPE ANNOTATION
STATUS ON
DATA "roads_label.shp"
LABELITEM "Nom"
#POSTLABELCACHE ON
#TRANSPARENCY 100
CLASS
LABEL
TYPE truetype
FONT "arial"
SIZE 10
MINDISTANCE 300
ANTIALIAS TRUE
POSITION cc
ANGLE AUTO
COLOR 100 100 100
OUTLINECOLOR 230 230 230
END
END
END
END # Mapfile
