[Mapserver-dev] Feature Questions..
Alan Steremberg
alans at wunderground.com
Sat Sep 27 16:29:07 EDT 2003
I have been trying to stay away from the PHP solution for a few reasons:
1 - it is going to conflict with the PHP version we currently run on our
site
2 - we have removed almost all the PHP code from our site, because it is
slow, and hard to integrate with our templating system (which makes it
impossible to co-brand, etc)
Instead of 'mapscript' i can just link against the mapserver libraries, I
am not worried about this. That is what I did with my first templated
version of the code.
I will have to dig through the mapscript API a bit more, and maybe swig
myself a C version.
Alan
Alan Steremberg
415-543-5021 x 103
http://www.wunderground.com
On Sat, 27 Sep 2003 woodbri at swoodbridge.com wrote:
> Alan,
> Most people do this with a little PHP/Mapscript. There have been a
> few examples posted where people have point in a database and do a
> query based on map extents to get the point then place them on the
> map with labels. It is easy to also then add the list of points with
> appropriate field info onto the page. Mapscript also allow you to get
> or calc the location of the points in image coordinates so
> calculating a bbox about the point is simple so you can create an
> image map also.
> If your concern is performance of loading php+mapscript over loading
> mapserver the former probably has a little additional overhead, but
> it is much easier to maintain a few mapscript apps, than to merge
> custom changes into mapserver unless you are thinking about extending
> the core mapserver CVS.
> Also, add the markers is probably much less overhead than doing the
> additional query.
> Just my 2 cents,
> -Steve W.
> On 25 Sep 2003 at 11:52, Alan Steremberg wrote:
> > Hi,
> > Here is one of the things I want to do:
> > 1) Display a zoomed in map of weather stations (from a database? from
> > a shapefile?) 2) If there are less than 20 on the map, number them
> > 1-20 as the symbol 3) include a table on the same page that lists the
> > 20 stations, with fields from the DBF/Database 4) be able to get the
> > xy image coordinates to make a client side click map
> > This would be similar to the hotel listings on Expedia when you click
> > 'show hotels on a map'.
> > I have dug through the mapserver code and read some of the
> > documentation.. I got somewhat close to this by changing the code so
> > it will do a query by rectangle (using the rectangle of the screen)
> > and then running a template query in addition to creating the map, ie:
> > combining the query and map display stuff into one web page.
> > It seems like what I really want is a concept where I can turn on a
> > 'template query' for each layer in the .map file, and have the code
> > store away the x,y location, and table fields when it goes to render
> > the shape. Otherwise, connectors that don't support random access to
> > each row (like the mapmygis.c connector) aren't supported.. Plus this
> > would mean that it wouldn't need to load the data twice. (Potentially
> > you would need to specify in the map file which fields to load, so
> > that it could store them all away).
> > Changing the symbols to 1-20 markers, seems like a whole different set
> > of modifications, or maybe it is already possible.
> > I have thought about doing some of this in mapscript, but really would
> > rather write everything in C...
> > I also have a prototype version that supports the 'clearsilver.org'
> > templating system, instead of the built in one. clearsilver is pretty
> > nice, we run our entire website using it..
> > Any ideas on how to implement these things:
> > 1 - without making code modifications?
> > 2 - in a manner that will make sense and be accepted as code
> > changes 3 - am i missing something completely? :-)
> > Alan
> > Alan Steremberg
> > 415-543-5021 x 103
> > Mapserver-dev mailing list
> > Mapserver-dev at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
