[Mapserver-dev] Next Generation MapScript API
Paul Spencer
spencer at dmsolutions.ca
Tue Apr 6 12:43:45 EDT 2004
is this intended to affect the swig-generated mapscript API and the
php_mapscript API? There is a significant push to release 4.2 in the
very near future and if this change is made, it is unlikely that
php_mapscript could be rewritten to conform to the new API.
I would rather see the MapScript API NG reserved for the next mapserver
release (4.4) which would give everyone more time to both implement and
test for compatibility. I must admit that I have a large toolkit built
on php_mapscript that I am trying to release right now and it requires
4.1/4.2 for many features, so I will have a very significant delay in
releasing it if this change is implemented for 4.2 :(
Paul
Frank Warmerdam wrote:
> Sean,
> I have been thinking a bit about your "next generation" MapScript API
> and names
> and what the implications might be for backward compatibility. For the
> record,
> let me say that I am a huge fan of backward compatibility ... to a fault no
> doubt.
> I would like to discuss what we can do to progress some of the naming
> conventions towards a "next generation" without undue breaking of backward
> compatibility.
> First I will try to summarize the changes I think you are proposing in the
> next generation API.
> 1) Change names of classes to not include the Obj suffix. Basically use
> the MapScript aliases Map, Layer, Class, Style, Image, Point, Line,
> Shape,
> OutputFormat, Symbol, Color, Rect, Projection, Shapefile, SymbolSet and
> FontSet for the C level names map_obj, layer_obj, styleObj, imageObj,
> pointObj, lineObj, shapeObj, outputFormatObj, symbolObj, colorObj,
> rectObj, projectionObj, shapefileObj, symbolSetObj and fontSetObj. The
> primary effect of this is in constructors which now would look like
> "x = mapscript.Map('adsf')" instead of "x = mapscript.map_obj('adsf')".
> 2) Change the getShape() method to return the shapeObj (instead of updating
> a shapeObj in place), and to place the tileindex after the shapeindex in
> the call list so the tileindex can be left defaulted.
> 3) Changed several methods on the geometry classes to be more specific:
> lineObj: get -> getPoint
> add -> addPoint
> set -> setPoint
> shapeObj: get -> getLine
> add -> addLine
> 4) Changed the copy() method on shapeObj to return a new reference
> instead of
> updating an existing one in place.
> Does this summarize the proposed changes? Assuming so, I would like to
> propose some options to allow the update while not generally breaking
> 1) Can we create some sort of stubs under the old constructor names that
> would allow old code to still make the objects the same way they used
> to?
> Even to creating a dummy class for each of the old names with only a
> a constructor that returns a new style object name? Or conversely,
> leave
> the actual class names with the old values, but create mini constructors
> with the new names to give nice creation semantics even if the objects
> thereafter go by their old names?
> 2) This is a hard one. I hate to change this because I presume getshape()
> is used alot so the change will cause lots of breakage. But I can see
> valid names for the new conventions and it isn't obvious what other name
> could be used that would make sense. Though unfortunate, perhaps we
> could
> call the new generation form getShapeByIndex()? This leaves us open
> to a
> getShapeNext() iterator at some point.
> 3) I can't see any reason we can't just have both sets of the get/add/set
> methods.
> 4) I think the old copy() semantics sort of suck and I like the new
> form. But
> to avoid conflicts could we call it clone() instead? The copy()
> copies a
> shapes information into another shape. The clone() makes a whole new
> clean
> instance.
> In each of the above cases I would suggest that the MapScript
> documentation only
> document the new style names and methods. What do you think? I would
> *like*
> this to be resolved before the 4.2 release if possible so we can issue
> it with
> new style mapscript documentation and that as the default but without
> breaking
> old MapScript applications.
> Best regards,
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
