[Mapserver-dev] Next Generation MapScript API
sgillies at frii.com
Tue Apr 6 13:45:54 EDT 2004
> Paul Spencer wrote:
>> is this intended to affect the swig-generated mapscript API and the
>> php_mapscript API? There is a significant push to release 4.2 in the
>> very near future and if this change is made, it is unlikely that
>> php_mapscript could be rewritten to conform to the new API.
>> I would rather see the MapScript API NG reserved for the next mapserver
>> release (4.4) which would give everyone more time to both implement and
>> test for compatibility. I must admit that I have a large toolkit built
>> on php_mapscript that I am trying to release right now and it requires
>> 4.1/4.2 for many features, so I will have a very significant delay in
>> releasing it if this change is implemented for 4.2 :(
> Paul,
> I have hadn't been thinking of changing the PHP side, though in the longer
> term
> we do need to think about how to keep the PHP reasonably in sync with the
> SWIG based MapScript implementations.
> I would be amendable to deferring "next generation" SWIG MapScript roll
> out
> to post-4.2 release. Currently (as I understand it) the default is to
> not
> use the next generation api stuff.
I just wrote up a long email in response to Frank's first post and then
my webmail session timed out after I hit send. Argh!!!!
I was thinking the new stuff would be more of a 5.0 thing since it
would certainly break some scripts and there are even more changes that
I'd like to convince y'all of implementing.
I've been wanting to see discussion of this for a while. Unfortunately,
I'm off on vacation tomorrow and might miss the bulk of it.
cheers,
Sean
