[Mapserver-dev] layerObj resultcache?
Howard Butler
hobu at iastate.edu
Mon Apr 12 12:36:15 EDT 2004
536 has included some enhancements as well as fixing the OBJECTID/SE_ROW_ID
bug. Enhancements include supporting version-specific queries through the
connection string (it will use default if not specified) and using new
constructs of the SDE C API for querying (se_queryinfo instead of
SE_SQL_CONSTRUCT). The benefits of the new construct is that SDE will be
able to support joins with this method, and it is a bit faster (SDE
pre-joins the feature and attribute tables in the database instead of
querying them individually and joining them client-side). ESRI has not
actively developed the SE_SQL_CONSTRUCT stuff since SDE 3.0 days as far as
I know.
The problem right now with the new changes is that SDE for Coverages is
causing all kinds of breakage because it looks like a duck but barks like a
dog. I am changing some of the calls that I make with the new code to be
sensitive to SDE for Coverages and work around it, but when I updated to
the newest mapscript Friday, all of my mapscript test code broke. I rolled
back to pre-change SDE code and am still getting the same errors in my test
code, so I suspect that something has changed.
Sean's latest mapscript docs
<http://users.frii.com/sgillies/projects/mapscript/mapscript.html> say
nothing about resultcache or resultcache object any more, and that is where
my code is hanging (query the layer for an attribute and set the map extent
to the bounds of the resultcache).
At 11:20 AM 4/12/2004, you wrote:
>Howard Butler wrote:
>>I upgraded to CVS version of mapscript to test my SDE changes for the
>>next release. Some of my past Python code depended on
>>layer.resultcache Did this get renamed? My inspection of mapscript.i
>>didn't show me much.
>You probably have to use the getResult(int i) method of the layerObj. I
>don't know if it's new or not in the SWIG MapScript, but that's always
>been the way to go with PHP MapScript.
>You talk about "SDE changes for the next release". Are you talking about
>bug 536 or about new changes?
>http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=536
>Should we mark this bug with the "4.2 release" target milestone, Steve?
>Daniel
> Daniel Morissette dmorissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
