[Mapserver-dev] 4.2beta Friday?
Daniel Morissette
dmorissette at dmsolutions.ca
Wed Apr 14 11:39:40 EDT 2004
Jonathan Meyers wrote:
> Daniel,
> Can you tell me...is the ability to specify the location of the projection
> files in either the 4.0.2 or 4.2 versions.
Are you referring to the new config option that was added by Frank a few
weeks ago? It's there in 4.2 only but it's not documented yet AFAIK, so
I have created a bug about documenting it:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=619
Also note that you can always set the PROJ_LIB environment variable to
specify the location of the projection files. This is a PROJ4 feature
and will work in any version of MapServer.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
