[Mapserver-dev] mapserver patch: mapmygis.c
David MacCormack
djm at maccormack.net
Fri Aug 6 23:39:18 EDT 2004
> From: Attila
> Subject: Re: [Mapserver-dev] mapserver patch: mapmygis.c
> Date: Fri, 6 Aug 2004 13:07:53 +0200
> On Thursday 05 August 2004 19:50, David MacCormack wrote:
> > Hi. Last week I submitted a patch for mapmygis.c. I have not seen any
> > discussion about it and I was wondering if anyone had looked at it and/or
> > considered applying it.
> Yes, I'm on it.
Excellent. Thanks, Attila.
> The need for the socket/port definition is valid it's just
> that I'm not sure the way it is done is the best since it will break any
> existing .map layers, so I might alter it a bit before integrating it into
> CVS to maintain backward compatibility.
Hmmm. It should not break existing map layers. The patch is backwards
compatible (e.g. current map layers which do not specify a port and
socket file should still work). Can you give me an example of something
that works before the patch but does not work once it is applied?
Dave
