[Mapserver-dev] 4.2.3 release for bug 707?
Steve Lime
steve.lime at dnr.state.mn.us
Wed Aug 25 11:57:25 EDT 2004
I've no objection to a 4.2.3 release yet this week. Are there other
patches to 4.2 that
should be applied before this happens? Seems like that version is
pretty stable...
Steve
>>> Daniel Morissette <dmorissette at dmsolutions.ca> 8/24/2004 4:55:57 PM
Steve,
This message was sent by Doug Cates to this list but it bounced. Please
include his address in your reply:
-------- Original Message --------
Subject: Re: [Bug 707] GetFeatureInfo does not return results when
projecting a map in WMS
Date: 24 Aug 2004 14:42:41 -0700
Organization: Moxi Media Inc.
To: mapserver-dev at lists.umn.edu
CC: dmorissette at dmsolutions.ca
References: <200408242118.i7OLI6N8029756 at lists.gis.umn.edu>
Steve,
A couple of my clients and I are eagerly awaiting this fix, which
apparently corrects the problem with the WMS GetFeatureInfo process
that
doesn't return any results if the requested SRS is not the same
projection as the data source.
Although I can work with CVS, my clients use the windows binaries.
This
is a critical MapServer WMS capability, and it is pretty much useless
to
us without this working. What do you think about posting a release of
4.2.3 soon?
Thanks a lot,
Doug
On Tue, 2004-08-24 at 14:18, bugzilla-daemon at lists.gis.umn.edu wrote:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=707
> ------- Additional Comments From dmorissette at dmsolutions.ca
2004-08-24 16:18 -------
> The fix is laready in the 4.2 branch and is going to be part of
4.2.3. I'm not
> sure when it will be released though since there are currently only
two fixes in
> the queue for 4.2.3. Perhaps you could send a note to mapserver-dev
to see what
> Steve thinks about releasing 4.2.3 soon.
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
