[Mapserver-dev] 4.2.3 release for bug 707?
Sean Gillies
sgillies at frii.com
Wed Aug 25 13:09:05 EDT 2004
--Apple-Mail-2--817571421
Content-Transfer-Encoding: 7bit
Content-Type: text/plain;
charset=US-ASCII;
format=flowed
On Aug 25, 2004, at 10:42 AM, Daniel Morissette wrote:
> Steve Lime wrote:
>> I've no objection to a 4.2.3 release yet this week. Are there other
>> patches to 4.2 that
>> should be applied before this happens? Seems like that version is
>> pretty stable...
> There was bug 426, but I took care of it a few minutes ago, so you can
> go ahead when you're ready.
Steve,
Please remember that I made some changes to the build script for 4.2.2.
Did you incorporate them into the official script? Am attaching that
script for you.
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
Content-Type: application/octet-stream;
x-unix-mode=0700;
name="release-4.2.2.csh"
Content-Disposition: attachment;
filename=release-4.2.2.csh
#!/bin/csh
setenv CVSROOT /data2/cvsroot
unalias rm
cvs -Q export -r rel-4-2-2 mapserver
mv mapserver mapserver-4.2.2
cd mapserver-4.2.2
rm -rf gdft
flex -Pmsyy -i -omaplexer.c maplexer.l
bison -p msyy -d -omapparser.c mapparser.y
cd mapscript/perl
swig -perl5 -shadow -outdir . -o mapscript_wrap.c ../mapscript.i
# Create Python module wrappers
cd ../python
# old school wrapper for Python 2.1 or older
swig -python -shadow -outdir . -o mapscript_wrap.c ../mapscript.i
# modern wrapper for Python 2.2+
# the Python setup.py script will try to use modern_mapscript_wrap.c
# if it exists.
# test to see if swig supports modern
set num = `swig -python -help |& grep -c '\-modern'`
# if so, run swig again
if ($num =~ "1") mkdir modern; swig -python -modern -outdir modern -o modern/mapscript_wrap.c ../mapscript.i
# End Python wrappers
# cd ../java
# cd ../tcl
cd ../../..
tar cf mapserver-4.2.2.tar mapserver-4.2.2
gzip *.tar
cp mapserver-4.2.2.tar.gz /data2/web-docs/ms-cvs/docs/dist
chmod 755 /data2/web-docs/ms-cvs/docs/dist/mapserver-4.2.2.tar.gz
rm mapserver-4.2.2.tar.gz
charset=US-ASCII;
format=flowed
--Apple-Mail-2--817571421--
