[Mapserver-dev] help
jacques
jacques.gariepy at dvp.ca
Thu Aug 26 13:09:06 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0006_01C48B6D.DE776800
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
help
=20
Hello!=20
my question still relates to the creation of a rectangle and to make it
possible to withdraw the coordinates=20
ground of this one from them. I will like can be to give the example of
the zoom by panning (exactly like the fourth tools in top on=20
this Web site http://sitn.ne.ch/index.html), but not zoomer, but to tap
coordinated of this one !
=20
Have you a small idea how to realize ? and if possible a small end of
code would be well !
=20
Thank you for your assistance and in the hope for not too you tire
because I am
initial in this world of the webserver and thus a blow of inch is quite
useful !!!!
=20
=20
Jacques Gari=E9py
Programmeur Internet
=20
DVP G=E9omatic Systems Inc.
49 du Bel-Air, suite 203
L=E9vis, Qu=E9bec, Canada, G6V 6K9
=20
CAN/USA 1-800-363-9513
=20
come see us: <http://www.dvp-gs.com/> http://www.dvp-gs.com
=20
Content-Type: text/html;
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C48B6D.DE003C30">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.StyleCourrierlectronique17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:612.0pt 792.0pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Tableau Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:36.0pt'>
<div class=3DSection1>
<p class=3DMsoNormal><span class=3DGramE><font size=3D1 =
face=3DArial><span
style=3D'font-size:9.0pt;font-family:Arial'>help</span></font></span><fon=
t
size=3D1 face=3DArial><span =
style=3D'font-size:9.0pt;font-family:Arial'><o:p></o:p></span></font></p>=
<p class=3DMsoNormal><font size=3D1 face=3DArial><span =
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>Hello! <o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:9.0pt;font-family:Arial'>my</span></font></span><font =
size=3D1
face=3DArial><span style=3D'font-size:9.0pt;font-family:Arial'> question =
still
relates to the creation of a rectangle and to make it possible to =
withdraw the
coordinates <o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:9.0pt;font-family:Arial'>ground</span></font></span><f=
ont
size=3D1 face=3DArial><span style=3D'font-size:9.0pt;font-family:Arial'> =
of this one
from them. I <span class=3DGramE>will like can</span> be to give the =
example of
the zoom by panning (exactly like the fourth tools in top on =
face=3DArial><span
style=3D'font-size:9.0pt;font-family:Arial'>this</span></font></span><fon=
t
Web site <a
href=3D"http://sitn.ne.ch/index.html">http://sitn.ne.ch/index.html</a>), =
but not <span
class=3DSpellE>zoomer</span>, but to tap coordinated of this one =
!<o:p></o:p></span></font></p>
font-family:Arial'>Have you a small idea how to <span =
class=3DGramE>realize ?</span>
<span class=3DGramE>and</span> if possible a small end of code would be =
well !<o:p></o:p></span></font></p>
font-family:Arial'>Thank you for your assistance and in the hope for not =
too
you tire because I am<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:9.0pt;font-family:Arial'>initial</span></font></span><=
font
in this
world of the <span class=3DSpellE>webserver</span> and thus a blow of =
inch is
quite useful !!!!<o:p></o:p></span></font></p>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
<div>
<p class=3DMsoNormal><strong><b><font size=3D2 face=3DArial><span =
lang=3DFR-CA
style=3D'font-size:10.0pt;font-family:Arial;mso-ansi-language:FR-CA;mso-n=
o-proof:
yes'>Jacques Gari=E9py</span></font></b></strong><span lang=3DFR-CA
style=3D'mso-ansi-language:FR-CA;mso-no-proof:yes'><o:p></o:p></span></p>=
</div>
<div>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span lang=3DFR-CA =
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:FR-CA;mso-no-proof:yes'>Progra=
mmeur
Internet</span></font><span lang=3DFR-CA =
</div>
<div>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
lang=3DFR-CA
style=3D'font-size:12.0pt;mso-ansi-language:FR-CA;mso-no-proof:yes'> =
;<o:p></o:p></span></font></p>
</div>
<div>
<p class=3DMsoNormal><font size=3D1 face=3DArial><span lang=3DFR-CA =
style=3D'font-size:
7.5pt;font-family:Arial;mso-ansi-language:FR-CA;mso-no-proof:yes'>DVP =
G=E9omatic
Systems Inc.</span></font><span lang=3DFR-CA =
</div>
<div>
style=3D'font-size:
7.5pt;font-family:Arial;mso-ansi-language:FR-CA;mso-no-proof:yes'>49 du
Bel-Air, suite 203</span></font><span lang=3DFR-CA =
</div>
<div>
style=3D'font-size:
7.5pt;font-family:Arial;mso-ansi-language:FR-CA;mso-no-proof:yes'>L=E9vis=
, Qu=E9bec,
Canada, G6V 6K9</span></font><span lang=3DFR-CA =
</div>
<div>
lang=3DFR-CA
</div>
<div>
style=3D'font-size:7.5pt;
font-family:Arial;mso-no-proof:yes'>CAN/USA =
1-800-363-9513</span></font><span
style=3D'mso-no-proof:yes'><o:p></o:p></span></p>
</div>
<div>
style=3D'font-size:
12.0pt;mso-no-proof:yes'> <o:p></o:p></span></font></p>
</div>
<div>
font-family:Arial;mso-no-proof:yes'>come see us: </span></font><span
style=3D'mso-no-proof:yes'><a href=3D"http://www.dvp-gs.com/"><font =
size=3D1
style=3D'font-size:7.5pt;font-family:Arial'>http://www.dvp-gs.com</span><=
/font></a></span><o:p></o:p></p>
</div>
style=3D'font-size:
12.0pt'><o:p> </o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_0006_01C48B6D.DE776800--
