[Mapserver-dev] Mapserver Bug Report
woodbri at swoodbridge.com
Tue Feb 3 10:32:29 EST 2004
Hi all,
I have been able to track down a problem I was having working with
Navtech data. It seems that they generate shapefiles for some layers
that appear to have valid dbf files that do not have any attribute
fields defined in them.
I looks like when these are acessed via a tileindex there is some
kind of memory overwrite happening. I had a streets layer that was
defined after this offending layer that was acting weird like all
that attributes were off by one or were being pulled from the wrong
column. When I commented out this layer everything when back to
normal.
OK, reading some code looks like mapxbase.c is not checking for the
case where nFields = 0 and is doing a bunch of malloc on zero bytes
and then stuffing values into those zero byte locations.
I'll write a bug on this also and while you might argue that I should
not have a dbf without attributes, I don't see any reason I shouldn't
but this is a nasty memory overwrite condition that I have been
fighting with off and on for 3 weeks and needs to be fixed one way or
another.
-Steve W.
