[Mapserver-dev] mapserv (CVS) WMS query
Eric Sokolowsky
eric.sokolowsky at gsfc.nasa.gov
Fri Jan 23 13:08:46 EST 2004
On Thu, 22 Jan 2004, Yewondwossen Assefa wrote:
> Hi There,
> I am not sure if this is the appropriate way of doing this. If you
> look in the same doc (section 7.2.3.4), It specifies that :
> A client may request the default Style using a null value (as in
> "STYLES="). If several layers are requested with a mixture of named and
> default styles, the STYLES parameter includes null values between commas
> (as in "STYLES=style1,,style2,,"). If all layers are to be shown using
> the default style, either the form "STYLES=" or "STYLES=,,," is valid.
> This is what is implemented in mapserver (since Mapserver does not
> advertize any styles, the default style wich is an empty string is the
> only thing valid).
> Maybe others on the list have comments on this.
> Is is possible for your wms client to send styles=
After reading the spec again, I agree with you. I have modified my client
to just send "styles=" when there is no advertised style. Thanks for
pointing this out.
____ __ Eric Sokolowsky (GST) NASA Goddard Space Flight Center
/ __/__/_/__ Visualization Programmer Scientific Visualization Studio
/ __/ _/ / _/ 301.286.3751 Mailstop 935.0 Bldg 28 Rm E102
/___/_//_/__/ eric.sokolowsky at gsfc.nasa.gov Greenbelt, MD 20771
