[Mapserver-dev] Re: Rendering engine enhancements
ANDY CANFIELD andy_canfield at hotmail.com
Mon Jul 19 18:15:36 EDT 2004
Ok you lost me in this dialog. So does that mean rotating PIXMAP symbols is
supported? If so do they have a rotation property or how do you set their
rotation? Can it be done per symbol on the fly or is it a rotation for all
symbols on that layer?
Thanks,
Andy
>From: "Steve Lime" <steve.lime at dnr.state.mn.us>
>To: <dmorissette at dmsolutions.ca>
>CC: <arnulf.christl at ccgis.de>, <Mapserver-dev at lists.gis.umn.edu>,
><j.l.h.hartmann at uva.nl>
>Subject: Re: [Mapserver-dev] Re: Rendering engine enhancements
>Date: Mon, 19 Jul 2004 16:58:47 -0500
>We chatted with Arnulf outside the last session at MUM. Frank drew some
>pictures in a notebook and I promptly slapped my forehead...
>Steve
> >>> Daniel Morissette <dmorissette at dmsolutions.ca> 7/19/2004 2:44:48 PM
>Steve Lime wrote:
> > I think it's a good idea but I think we still need both. MapServer
> > vector symbols are turned into
> > bitmaps on-the-fly and then used as tiled fill (or brush).
>Consequently
> > (as Frank pointed out) only a few
> > hatching patterns are possible using this scheme.
>Is the problem only related to the white corners you would get when
>rotating the symbol or is there something else I didn't think of. When
>did Frank send that message you refer to? I don't remember seeing it.
> > A hatched symbol type
> > could still leverage
> > brushes and patterns (basically anything you could do with a line
> > symbol now)...
>ah ok... that would be nice.
> > I believe rotated PIXMAPs are already supported. If I recall Brent
> > Frasier and his staff contributed
> > that patch a while back.
>I didn't know we could rotate PIXMAP symbols, I'll have to give that a
>try.
>Daniel
>   Daniel Morissette               dmorissette at dmsolutions.ca
>   DM Solutions Group              http://www.dmsolutions.ca/
>_______________________________________________
>Mapserver-dev mailing list
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
_________________________________________________________________
Don’t just search. Find. Check out the new MSN Search!
http://search.msn.click-url.com/go/onm00200636ave/direct/01/
