[Mapserver-dev] Problems with EPPL7 files...
Norman Vine
nhv at cape.com
Thu Jul 29 12:43:30 EDT 2004
Steve Lime writes:
> I know nobody know anything about that format, but there's a very
> curious issue with them. Anyway, check out:
> http://maps.dnr.state.mn.us/cgi-bin/mapserv43?map=/usr/local/www/docs/testing/multiple/test.map&layer1=landsat&layer2=shr30im3
> Notice anything wierd with the bottom image? ;-)
> Used to work fine in 3.6. Any ideas?
It looks as if it is fliped and rotated
This is similar to what a USGS DEM looks like if it is read as
a row major rather then a column major format
i.e C arrays vs Fortran arrays
HTH
Norman
