[Mapserver-dev] Scale-Dependent Renderers
bartvde at xs4all.nl bartvde at xs4all.nl
Fri Jul 30 02:20:52 EDT 2004
Hi Paul,
are you doing this conversion process by hand or are you writing an AXL to
MAP utility?
Best regards,
Bart
> We recently received a large ArcIMS AXL file, to do a test conversion
> to Mapserver, and one of the things the struck was that AXL has support
> for scale dependent renderers.
> I was struck again by the utility of the concept today, as I wrote four
> scale dependent layers to represent the same data table at four
> different resolutions.  Often, we want to render the same things
> differently at different scales, and forcing the choice at the layer
> level gets very verbose, very fast.
> An example would be rendering roads data. At a certain level of zooming
> in, I want to start rendering features somewhat wider than I would at
> full zoom out level.
>       Paul Ramsey
>       Refractions Research
>       Email: pramsey at refractions.net
>       Phone: (250) 885-0632
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
