[Mapserver-dev] mapserver patch: mapmygis.c
David MacCormack
djm at maccormack.net
Fri Jul 30 14:46:49 EDT 2004
This message is in MIME format. The first part should be readable text,
while the remaining parts are likely unreadable without MIME-aware tools.
Send mail to mime at docserver.cac.washington.edu for more info.
---1941603961-1988021196-1091213209=:19527
Content-Type: TEXT/PLAIN; charset=US-ASCII
Hello.
This is a patch for mapmygis.c. It's pretty simple. All it does is
allow the user to specify the mysql socket and port inside a map
``CONNECTION'' statement if s/he so desires. It's backwards compatible
with the current format, so the user can do either of the following.
current way:
CONNECTION "host:user:pass:db:bin:"
new way:
CONNECTION "host:user:pass:db:3306:/path/to/mysql.sock:bin:"
Dave
Content-Type: TEXT/PLAIN; charset=US-ASCII; name="mapmygis.patch"
Content-Transfer-Encoding: BASE64
Content-ID: <Pine.LNX.4.44.0407301446490.19527 at the-wall.maccormack.net>
Content-Description:
Content-Disposition: attachment; filename="mapmygis.patch"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---1941603961-1988021196-1091213209=:19527--
