[Mapserver-dev] [PATCH] mapraster.c - fixing memory leaks
Sean Gillies
sgillies at frii.com
Tue Jun 15 22:24:27 EDT 2004
Nevermind, looks like we are protected from that with C. I actually
haven't used a goto since my student FORTRAN days.
Sean
On Jun 15, 2004, at 8:00 PM, Sean Gillies wrote:
> As long as the GOTO jump remains inside a function I'm fine with them.
> If we start using GOTO to have alternate ways for functions to return,
> it will eventually break our scripting interface.
> Sean
> On Jun 15, 2004, at 5:03 PM, Steve Lime wrote:
>> Patch aside, what do folks think about using goto's? They seem a great
>> help with things like clean-up. However there's not one in the code
>> presently so I was wondering if there's a bias...
>> Steve
>> Stephen Lime
>> Data & Applications Manager
>> Minnesota DNR
>> 500 Lafayette Road
>> St. Paul, MN 55155
>> 651-297-2937
>>>>> "Mladen Turk" <mturk at apache.org> 06/02/04 11:18 AM >>>
>> Hi all,
>> Mapraster has a memory leak bug not freeing allocated temporary layer.
>> The quickest solution would be to just add the tlptemp variable, but
>> I've
>> added standard 'cleanup:' label for function exiting.
>> Having something like mpatrol gives:
>> Total unfreed bytes: 92899
>> Peak memory usage: 1699139
>> Largest allocation: 235750
>> Smallest allocation: 1
>> Total Allocations: 513
>> Total Frees: 505
>> Peak Allocations: 385
>> The patch for mapraster.c gives:
>> Total unfreed bytes: 14
>> Total Frees: 512
>> So we've save cca 92K of memory on each request.
>> Here is the patch:
>> (I can file a bug report if needed)
>> There is still 14 bytes left hanging but the reason is in the
>> getString()
>> from mapfile.c used somewhere :). I'll try to hunt that down.
>> MT.
>> Mapserver-dev mailing list
>> Mapserver-dev at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
