[Mapserver-dev] [PATCH] mapraster.c - fixing memory leaks
John Beisley - RSG
josb at pml.ac.uk
Wed Jun 16 11:10:09 EDT 2004
Daniel Morissette wrote:
> Steve Lime wrote:
>> Patch aside, what do folks think about using goto's? They seem a great
>> help with things like clean-up. However there's not one in the code
>> presently so I was wondering if there's a bias...
> I've always avoided them because I was told way back when by some
> profs that they were evil, but I guess if they're properly used they
> could help keep the code cleaner sometimes.
> If we use them then I think it should only be when absolutely
> necessary. It is generally possible to structure a function so that
> you can properly cleanup without the use of gotos and without
> increasing complexity.
> My 0.02$
> Daniel
I'm not a mapserver dev, but if you're talking about cleaning things up
after an error has occured then using things like exceptions is usually
the way forward. They come as standard in C++, but in C you have to do
some fancy stuff. I am aware of, but have never used, an exception
library for C at www.zork.org. Wrapping code in try... finally blocks
should make tidying up after an error somewhat cleaner.
- John
Website: www.pml.ac.uk
Registered Charity No. 1091222
Company No. 4178503
This e-mail, its content and any file attachments are confidential.
If you have received this e-mail in error please do not copy,
disclose it to any third party or use the contents or attachments
in any way. Please notify the sender by replying to this e-mail or
e-mail forinfo at pml.ac.uk and then delete the email without making
any copies or using it in any other way.
The content of this message may contain personal views which are
not the views of Plymouth Marine Laboratory unless specifically
stated.
Email transmission cannot be guaranteed to be secure or error free
