[Mapserver-dev] MySQL feature data joins
David Horowitz
dahoro at umd.edu
Thu Jun 17 09:20:35 EDT 2004
Thanks for your reply. The fact that it is impossible to use joined data to classify a map causes major problems for my application. Using mapserver, I generate maps of roads in my area which are colored based on current vehicle speed information that my laboratory receives every 5 minutes from detectors around the state.
Since I have been unable to classify my maps through the database directly, my workaround solution has been to update a column in the corresponding DBF file with the new speed data every five minutes. This is obviously not the best solution, nor does it work with future goals for the application.
Any ideas on how to approach this problem? There must be some way to color the roads in my maps based on data from the lab's database rather than from the DBF file.
Thanks for you help, once again.
-----Original Message-----
To: <woodbri at swoodbridge.com>, <dahoro at umd.edu>
Date: Wed, 16 Jun 2004 23:38:36 -0500
Subject: Re: [Mapserver-dev] MySQL feature data joins
Joins are query only, that is once you'd got your feature(s) then joins
are ok. You can't use joined data to classify a map. The reason is
performance (and it gets a bit complicated to code given the way layers
work), joins can be quite slow.
The alternative is to use MapScript (equally slow), perhaps OGR with
point data, use PostGIS, or pre-process your data a bit.
Sorry,
Steve
>>> Stephen Woodbridge <woodbri at swoodbridge.com> 06/16/04 2:47 PM >>>
David Horowitz wrote:
> Hello all,
> I'm writing an application which gets its spatial data from shapefiles
but its feature data from a SQL data source (either MySQL or Oracle). I
have read the Wiki topic "JoinDatasources" but did not find its
explanation of how to go about this sufficient. Any help here would be
appreciated.
> To be more specific, I have all my data loaded into a MySQL database
(using the shp2mysql tool). Supposing the source shapefile is
"statemap.shp" and the feature column I wanted to access in my database
was called "title" what would my mapfile entry look like? Is using a
join the way to go about solving this problem?
I have a similar situation where all my spatial data is in shapefiles
and I have Summary File 1 data in MySQL. How would I set up a layer to
to JOIN MYSQL_ZIPCODE to DBF_ZIPCODE attributes and then specify
MYSQL_INCOME as the CLASSITEM so I can color polygons based on INCOME
values from Summary File 1.
I read the docs on this but the details were not obvious and there was a
phrase about MYSQL JOINs only being supported in a query template which
did not make any sense to me.
-Steve
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
