[Mapserver-dev] Any experience with SQL Relay?
David Blasby
dblasby at refractions.net
Wed Jun 23 13:16:14 EDT 2004
Sean Gillies wrote:
> Thanks, Dave. I think that we'd have to write new connector code that
> would
> be inspired by that in mappostgis.c, but using the sqlrelay API. I'm still
> undecided about starting in on this.
If you're going to do that, I suggest you make a "mapdatabase.c" file
that would serve Oracle, PostGIS, SQLrelay, MySQL, and SDE layers.
Having everything unified in one file would be a big help - only one
place to test and find bugs...
"mappostgis.c" should be re-written instead of modified.
** Ideally I'd like to see the way the current query mechanism works be
improved. It might be worth experimenting with a "query cache" - it
would significantly improve performance for all the DB layers, at the
cost of cache memory.
** I'd also like to see the postgis layer *not* read all the results
into memory. This can be done with "FETCH N" instead of the current
"FETCH ALL" commands on the cursor. Ideally, you could thread the query
- improving performance and significantly cutting down on memory usage.
The threading portion is optional, but the "FETCH N" rows command is
relatively simple...
dave
