[Mapserver-dev] Re: [Mapserver-users] WMS Problems...
Frank Warmerdam
warmerdam at pobox.com
Fri Mar 5 12:29:12 EST 2004
Steve Lime wrote:
> I've moved this to mapserver-dev. Ok, to sum up:
> 1) Looks like formats for 1.0.0 are hardcoded. I can't say who's using
> version more
> frequently but it seems to me that the process to output formats should
> be the same
> across versions even if what appears to the user is different. I would
> vote to sync
> that process.
Steve,
OK, would you like me to correct the 1.0.0 behaviour? I sort of had
the impression someone was already addressing that.
> 2) Formats cannot be excluded from presentation. Bug already exists for
> this.
> 3) There is no way (within the same mapfile) to have multiple versions
> of the same
> format. To me this is a big problem especially with very flexible
> formats like TIFF. Can
> we simply choose to support one? Frank's makes the most sense to me,
> but I can
> see where simply a name may be to cryptic.
I think there is already a way, which is to just list different varieties
with the different extended mime options. I think this would be completely
under the control of the person writing the .map file already (with the
exception of 1.0.0 of course).
> This covers almost everything in my original note except for 1 thing.
> Why does
> tiff show up with 1.1.x capabilities documents if no tiff image output
> format is
> defined in the mapfile? The reason this is a problem is that requesting
> a tiff generates
> an error.
This happens because there is an internal default definition for GeoTIFF if
GDAL is configured. I don't understand why actually requesting it would
generate an error. Could you submit a bug with a support mapping file and data
demonstrating the problem?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
