[Mapserver-dev] Generic tiling (for shapefiles and rasters)...
woodbri at swoodbridge.com woodbri at swoodbridge.com
Mon Mar 8 20:58:18 EST 2004
Hi Steve,
We talked about the need to improve on the tile4ms to validate the
all the files being added to the tileindex have the same fields and
order of fields. What about creating a tileindex.mdt file that would
be a metadata file with the template info for the tileindex. This
file can be created by tile4ms and be a simple text file that anyone
anyone can create that has the dbf definition that was validated when
tile4 ms was run.
This file could be opened if the tileindex is a shapfile instead of
scanning the files. This would imply that for non shapfile
tileindexes that you can request a similar metadata structure for the
layer.
Another option would be to require the meta data to included in the
METADATA ...END object of the LAYER in the mapfile is the data layer
is shapfiles.
How does this play with the fact that I build tileindexes for Tiger
data based on the county directory and not on the actual files in the
layer. So the data is organized like this:
SHAPEPATH "/data/mdata/"
LAYER
  TILEINDEX "tiger-tile"
  DATA "roads"
END
LAYER
  DATA "waterpoly"
END
the LOCATION in the tileindex look like
/data/mdata/tiger2k/25/25015/
/data/mdata/tiger2k/25/25017/
etc
and
files are like:
/data/mdata/tiger2k/25/25015/roads.*
/data/mdata/tiger2k/25/25015/waterpoly.*
/data/mdata/tiger2k/25/25017roads.*
/data/mdata/tiger2k/25/25017/waterpoly.*
etc
This cuts down on the number of records in the tileindex from about
33,000 to about 3300 at the minor expense that some layers are
marginally smaller than the county bounds, but the biggest layers
"roads" always defines the boundary anyway. and drives performance.
-Steve W.
On 8 Mar 2004 at 17:06, Steve Lime wrote:
> Hi Folks: As I've been putzing with enhanced tiling support I've been
> trying to generalize things
> so that one wouldn't be limited to simply shapefile tile indexes. For
> raster data that shouldn't be
> an issue using another LAYER as a tile layer. This would allow you, for
> example, to store your
> tileindex in PostGIS and reference images on the file system. For
> shapefiles it's not that simple
> though because of this need to open one tile as a template (to get item
> names and such). I can'd
> find an easy way to retrieve, for example, the 1st record in a layer.
> (For rasters this isn't an
> issue since we don't need a template.)
> So, there are a couple of options:
>   - say the hell with non-shapefile tile indexes for shapefiles, but
> allow them for rasters
>   - figure out a method to retrieve the nth element of a datasource
> (not by ID, but by position)
>   - retool the msLayer... functions and move the msLayerWhichItems
> functionality someplace else
> I'm partial to the first one. I can't imagine anyone using
> non-shapefile tile indexes with shapefiles
> (I mean, most folks would put everything in PostGIS or SDE). Raster
> data are where that functionality
> makes sense.
> I just want to run the idea by folks to make sure I'm not overlooking
> some obvious solution.
> Steve
> Mapserver-dev mailing list
> Mapserver-dev at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
