[Mapserver-dev] Raster Queries / Query Caches
Daniel Morissette
dmorissette at dmsolutions.ca
Tue Mar 9 14:16:55 EST 2004
Frank Warmerdam wrote:
> My big question is how should I fit this into the query model?
Not an easy one I agree!
> 2) What should be done about queries that return very large result sets?
> How do folks avoid accidentally very large query results in the vector
> realm? Would it be sensible to have a "max hits" value in the query API?
> Perhaps the default could be unbounded, but a max hits provided by some
> mechanism optionally?
With very hi-res raster images viewed at very small scale, even a point
query with a tolerance of 2-3 pixels could generate thousands or even
millions of results.
Setting a "max hits" may be a good way to handle this, but that would
return only a subset of the results, which may or may not be
representative of the complete queried area.
Would it be possible to offer the option to return a kind of histogram
of the selected pixels? In this case the result would be a set of
raw_value/red/green/blue/count where count is the number of pixels that
have that discrete value.
I'm thinking out loud here... maybe the entries in the histogram could
be driven by the set of classes defined on the layer? i.e. you get one
count value per class.
> 3) Are there presentation methods that should be implemented for raster
> query results other than the normal template mechanisms used for vectors?
We may have to think about how we represent those results with a WMS
GetFeatureInfo in GML format... um... probably just a collection of GML
points. In the case of text/html GetFeatureInfo, the results would be
driven by the same query template mechanism as the mapserv CGI.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
