[Mapserver-dev] Generic tiling (for shapefiles
and rasters)...
Steve Lime
steve.lime at dnr.state.mn.us
Wed Mar 10 11:51:15 EST 2004
It will be backwards compatible. The first test when opening a tiled
layer will check
to see if a layer of the same name exists. If not then it proceeds as
in the past.
A new layer type is being added, akin to TYPE QUERY...
Steve
>>> Daniel Morissette <dmorissette at dmsolutions.ca> 3/9/2004 11:33:37 PM
Steve Lime wrote:
> The modifications I'm talking about should have no effect on
file-based
> versus directory-based access. The location (or TILEITEM) contents
are
> applied to the layer that is tiled regardless of the where the
tileindex
> is defined. Your old mapfile would still work. You could re-write as
> LAYER
> NAME tiger-tile
> DATA tiger-tile
> END
> LAYER
> TILEINDEX "tiger-tile"
> DATA "roads"
> END
> LAYER
> DATA "waterpoly"
> END
I think I remember reading something about this but didn't realize that
you were moving ahead with this approach. I would like to raise the
backwards compatibility flag since TILEINDEX would now be the name of a
tile layer instead of the path to a shapefile.
Perhaps something we could do to remain backwards compatible is that if
a layer by the specified name exists then it is used as tile index. And
if no layer with the specified name exists then the TILEINDEX value is
assumed to be a shapefile like in older version and a tileindex layer
would be implicitly defined for it by the parser.
Would this dual behavior be just too complicated to understand for
users? Should we consider creating a new keyword for the tile index
layer reference instead?
Oh, and another note: we'll probably need a new status flag or layer
type (e.g. MS_LAYER_TILEINDEX) to indicate that the tile layer is not a
real layer and shouldn't show up in WMS/WFS capabilities, or in user
interfaces produced by MapScript apps.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
