[Mapserver-dev] CONFIG Keyword
Sean Gillies sgillies at frii.com
Sun Mar 14 10:29:18 EST 2004
On Mar 13, 2004, at 1:32 PM, Frank Warmerdam wrote:
> Folks,
> I have added the CONFIG keyword for use in the MAP object in a .map
> file.
> It takes two arguments, a key and a value.  The PROJ_LIB key will
> attempt to
> force PROJ.4 to use the provided value for looking up files like the
> epsg
> file, and the datum shift files.
> I am hoping that setting the PROJ_LIB variable will be the main use of
> this keyword for most people, helping them avoid having to set external
> environment variables.
> Any other value will be passed on to CPLSetConfigOption().  This
> provides
> customized control of some GDAL and OGR driver behaviours.   Details on
> such options would be found in specific GDAL driver documentation.  My
> main
> reason for implementing all this is because it is needed for
> controlling some
> behaviour of the OGR DODS driver.
> In addition to adding the CONFIG keyword in map file parsing, I also
> add
> a setConfigOption() and getConfigOption() method in mapscript.i, and
> documented
> them in mapscript.txt.  I even tested them briefly in a python
> mapscript script.
> I am getting the hang of MapScript!
> I haven't updated the mapfile reference yet, but I intend to do that
> soon.
> Changes all committed.  Whack me if I screwed something up.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
Frank,
I have a suggestion: to use, perhaps, MapServer's hashTableObj
structure for
the config instead of a pair of string arrays?  One of these days I am
going
to figure out how we can expose MapServer's hashes to SWIG and then we
will
be able to drop the setOption/getOption methods in favor of
    mapobj.config['foo'] = 'bar'
    layerobj.metadata['wms_title'] = 'wms layer'
Could you also update the msCopyMap function in mapcopy.c so that it
properly
replicates your new mapObj structure members?
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
