[Mapserver-dev] 4.2 beta3 tomorrow?
Daniel Morissette
dmorissette at dmsolutions.ca
Thu May 13 18:01:50 EDT 2004
Guys,
There seem to be a good set of fixes in the 4.2 CVS branch now (see
below). What do you think of releasing a 4.2beta3 tomorrow? Hopefully
that would be the last one before the release...
If that's ok with everyone then I could tag the source for
rel-4-2-0-beta3 around lunch time tomorrow and then Steve can package it
and put it up on the web site as usual.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Version 4.2-???
- Fixed another write past end of buffer in INIMAGE WMS errors (bug 644)
- Removed "xbasewohoo" debug output when using JOINs and fixed a few
error messages related to MySQL joins (bug 652)
- No more Python-stopping but otherwise benign errors raised from
msDrawWMSLayer() (bug 650).
- Finished prototyping all MapServer functions used by SWIG-Mapscript
and added 'void' to prototypes of no-arg functions, eliminating all
but two SWIG-Mapscript build warnings (bug 658).
- Fixed mapwcs.c so that gdal.h and cpl_error.h are not included if
USE_WCS_SVR is not enabled ... which is never is in 4.2.
- msBuildPath() no longer used with temporary filenames when saving images
via GDAL.
- Bug 493: fix the raster cracking fix. The last fix introduced a serious
heap corruption / errant pointer problem in some render cases.
- Resolved issue with pens and dynamically drawing points (bug 663).
- Removed unused metadata gml_uri in WFS code (Bug 527)
