[Mapserver-dev] Rotated Map Rendering
Sean Gillies
sgillies at frii.com
Thu May 20 10:06:58 EDT 2004
On May 20, 2004, at 7:06 AM, Stephen Woodbridge wrote:
> OK, I hate to jump into a thread late and into one that I have only
> half been following, but what the hey:
> The view model that I have always worked with in the CAD/CAM and
> graphics world is the standard camera model i.e.: world space ->
> projected space -> to clipped 2d space -> viewport space or device
> coordinates. OK so I know we are not trying to redesign the mapserver
> viewing pipeline.
> So I liked the idea that someone suggested about an output frame or
> view port definition that would describe a final transformation of the
> image. I was thinking that this could be defined to cause a simple
> image transform as the image is output. For now only allow ROTATION in
> increments of +-90 degrees. and this would be handled just before the
> OUTPUTFORMAT processor is invoked. May be like
> OUTPUTFORMAT
> ROTATEOUTPUT 90
> END
> ALSO, If this is set then image.x and image.y are transformed on input
> so they align correctly with the internal image. If other parameters
> need to be adjusted to them at the same time. This keeps mapserver
> pretty much insulated from any of these changes.
> By limiting the transforms to +-90 degrees increments the transform
> becomes one of just swapping x/y values and/or min/max values which
> should be fast and the same for pixel outputs.
> So I probably have missed the whole point of this discussion and this
> is just extraneous noise so feel free to ignore it if it doesn't
> apply.
> -Steve W.
Steve W., thanks for mentioning the camera model, that's what I was
trying to
describe in my previous email. Conceptual and programmatic separation
between the map and the view model would be a good thing. For example,
in
the real world when you take a map and rotate it -- it is the exact same
map, still pointing north (in most common cases) -- only the the view of
it has changed. If we add rotation to the mapObj itself, we add
complexity
and make it less like a real-world object. This could make it harder
for
users to understand.
I think that the WEB element is a more natural spot for the rotation
stuff
than the OUTPUTFORMAT. We are already keeping view model-ish and
application-specific parameters like MAXSCALE there.
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
