[Mapserver-dev] Floating point precision problem in the WMS module
Daniel Morissette dmorissette at dmsolutions.ca
Tue May 25 09:42:19 EDT 2004
Jean-Henry Berevoescu wrote:
> And yes, I tried strtold too (when I tried the lesser strtod).
> (I run on Mandrake 10 - but I don't think that should be an
> issue. After all Mandrake is a Linux and it originally started
> as an RH clone)
I'm not sure what to suggest, even K&R (the ultimate C reference) says
that atof() should return a double:
   double atof(const char *s)
       atof converts s to double; it is equivalent to
       strtod(s, (char**)NULL).
I have created a bug about this:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=678
Could you please add yourself to the CC of the bug, and add an example
of a GetMap request (at least the BBOX part) where the digits are
truncated... we'll continue the discussion there.
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
