[Mapserver-dev] [PATCH] mapswf and mappdf memory leaks
Daniel Morissette
dmorissette at dmsolutions.ca
Fri May 28 14:41:44 EDT 2004
Mladen Turk wrote:
> Hi all,
> The patch resolves memory leaks in mapswf and mappdf caused by multiple
> strdup's on a single variable (driver).
> Interesting that the code (using const char *, instead strdup) already
> exists in a part of mapswf.
> MT.
> Index: mapswf.c
> RCS file: /data2/cvsroot/mapserver/mapswf.c,v
> retrieving revision 1.36
> diff -u -r1.36 mapswf.c
> --- mapswf.c 11 May 2004 13:54:29 -0000 1.36
> +++ mapswf.c 28 May 2004 06:25:41 -0000
> @@ -17,6 +17,8 @@
> #include <assert.h>
> #if !defined(_WIN32)
> #include <zlib.h>
> +#else
> +#include "zlib.h"
> #endif
> #include "map.h"
> @@ -824,7 +826,7 @@
> imageObj *image = NULL;
> - char *driver = strdup("GD/GIF");
> + const char *driver = "GD/GIF";
> assert( strcasecmp(format->driver,"SWF") == 0 );
> image = (imageObj *)calloc(1,sizeof(imageObj));
> @@ -875,19 +877,19 @@
> else
> #ifdef USE_GD_GIF
> - driver = strdup("GD/GIF");
> + driver = "GD/GIF";
> #else
> #ifdef USE_GD_PNG
> - driver = strdup("GD/PNG");
> + driver = "GD/PNG";
> #else
> #ifdef USE_GD_JPEG
> - driver = strdup("GD/JPEG");
> + driver = "GD/JPEG";
> #else
> #ifdef USE_GD_WBMP
> - driver = strdup("GD/WBMP");
> + driver = "GD/WBMP";
> #endif
> #endif
> @@ -2858,23 +2860,23 @@
> imageObj *imagetmp;
> //int nTmp = -1;
> SWFShape oShape;
> int bFreeImage = 0;
> #ifdef USE_GD_GIF
> #else
> #ifdef USE_GD_PNG
> #else
> #ifdef USE_GD_JPEG
> #else
> #ifdef USE_GD_WBMP
> #endif
> #endif
> Index: mappdf.c
> RCS file: /data2/cvsroot/mapserver/mappdf.c,v
> retrieving revision 1.22
> diff -u -r1.22 mappdf.c
> --- mappdf.c 8 May 2003 04:54:02 -0000 1.22
> +++ mappdf.c 28 May 2004 06:26:41 -0000
> @@ -128,7 +128,7 @@
> imageObj *oImage = NULL;
> PDF *pdf = NULL;
> assert( strcasecmp(format->driver,"PDF") == 0 );
> @@ -186,19 +186,19 @@
> else
> #ifdef USE_GD_GIF
> #else
> #ifdef USE_GD_PNG
> #else
> #ifdef USE_GD_JPEG
> #else
> #ifdef USE_GD_WBMP
> #endif
> #endif
> @@ -1452,7 +1452,7 @@
> PDF *pdf = NULL;
> imageObj *image_tmp = NULL;
> int iReq = -1;
> char *jpeg = NULL;
> int nLength = 0, nResult = 0;
> //char ttt[200];
> @@ -1460,19 +1460,19 @@
> int bRasterOutput = 0;
> #ifdef USE_GD_GIF
> #else
> #ifdef USE_GD_PNG
> #else
> #ifdef USE_GD_JPEG
> #else
> #ifdef USE_GD_WBMP
> #endif
> #endif
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
