[Mapserver-dev] copyProperty in mapserver
Mladen Turk
mturk at apache.org
Mon May 31 05:04:05 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_007A_01C446FE.F95F5AF0
Content-Type: multipart/mixed;
boundary="----=_NextPart_001_007B_01C446FE.F95F5AF0"
------=_NextPart_001_007B_01C446FE.F95F5AF0
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Here is the patched mapcopy.c, that uses few macros instead copyProperty
functions.
I'm sending the complete file instead the patch, cause it's quite a large one
Also, I've moved msCopySymbol and msCopySymbolSet from mapsymbol.c so that the
new macros can be used (IMO those functions belongs in the mapcopy anyhow), so
if applied those functions has to be removed from mapsymbol.c.
I've tested them and AFAICT there are no memory leaks, nor heap corruption
caused by copyStringProperty used in the previous implementation.
MT.
name="mapcopy.c.txt"
Content-Transfer-Encoding: quoted-printable
Content-Disposition: attachment;
filename="mapcopy.c.txt"
/**********************************************************************=0A=
* =0A=
* $Id: mapcopy.c,v 1.24 2004/04/29 17:29:44 sean Exp $=0A=
*=0A=
* Project: MapServer=0A=
* Purpose: Functions to allow copying/cloning of maps=0A=
* Author: Sean Gillies, sgillies at frii.com=0A=
*=0A=
* Notes: These functions are not in mapfile.c because that file is =0A=
* cumbersome enough as it is. There is agreement that this code and=0A=
* that in mapfile.c should eventually be split up by object into =0A=
* mapobj.c, layerobj.c, etc. Or something like that. =0A=
*=0A=
* Unit tests are written in Python using PyUnit and are in=0A=
* mapscript/python/tests/testCopyMap.py. The tests can be =0A=
* executed from the python directory as=0A=
*=0A=
* python2 tests/testCopyMap.py=0A=
*=0A=
* I just find Python to be very handy for unit testing, that's all.=0A=
*=0A=
*********************************************************************/=0A=
=0A=
#include <assert.h>=0A=
#include "map.h"=0A=
#include "mapsymbol.h"=0A=
=0A=
/***********************************************************************=0A=
* Make the CVS Id available in mapcopy.o through 'strings' *=0A=
**********************************************************************/=0A=
=0A=
#ifndef DISABLE_CVSID=0A=
# define CPL_CVSID(string) static char cpl_cvsid[] =3D string; \=0A=
static char *cvsid_aw() { return( cvsid_aw() ? ((char *) NULL) : =
cpl_cvsid ); }=0A=
#else=0A=
# define CPL_CVSID(string)=0A=
#endif=0A=
=0A=
CPL_CVSID("$Id: mapcopy.c,v 1.24 2004/04/29 17:29:44 sean Exp $");=0A=
=0A=
/*=0A=
* struct assignment helper.=0A=
*/=0A=
#define MS_COPYSTELEM(name) (dst)->##name =3D (src)->##name=0A=
=0A=
#define MS_MACROBEGIN do {=0A=
#define MS_MACROEND } while (0) =0A=
=0A=
#define MS_COPYRECT(dst, src) \=0A=
MS_MACROBEGIN \=0A=
(dst)->minx =3D (src)->minx; \=0A=
(dst)->miny =3D (src)->miny; \=0A=
(dst)->maxx =3D (src)->maxx; \=0A=
(dst)->maxy =3D (src)->maxy; \=0A=
MS_MACROEND=0A=
=0A=
#define MS_COPYPOINT(dst, src) \=0A=
MS_MACROBEGIN \=0A=
(dst)->x =3D (src)->x; \=0A=
(dst)->y =3D (src)->y; \=0A=
(dst)->m =3D (src)->m; \=0A=
MS_MACROEND=0A=
=0A=
#define MS_COPYCOLOR(dst, src) \=0A=
MS_MACROBEGIN \=0A=
(dst)->pen =3D (src)->pen; \=0A=
(dst)->red =3D (src)->red; \=0A=
(dst)->green =3D (src)->green;\=0A=
(dst)->blue =3D (src)->blue; \=0A=
MS_MACROEND=0A=
=0A=
#define MS_COPYSTRING(dst, src) \=0A=
MS_MACROBEGIN \=0A=
if ((dst) !=3D NULL) \=0A=
msFree((dst)); \=0A=
if ((src) !=3D NULL) \=0A=
(dst) =3D strdup((src)); \=0A=
else \=0A=
(dst) =3D NULL; \=0A=
MS_MACROEND=0A=
=0A=
=0A=
* msCopyProjection() *=0A=
* *=0A=
* Copy a projectionObj *=0A=
=0A=
int msCopyProjection(projectionObj *dst, projectionObj *src) {=0A=
=0A=
#ifdef USE_PROJ=0A=
int i;=0A=
dst->numargs =3D src->numargs;=0A=
for (i =3D 0; i < dst->numargs; i++) {=0A=
MS_COPYSTRING(dst->args[i], src->args[i]);=0A=
}=0A=
if (dst->numargs !=3D 0) {=0A=
if (msProcessProjection(dst) !=3D MS_SUCCESS)=0A=
return MS_FAILURE;=0A=
=0A=
}=0A=
#endif=0A=
return MS_SUCCESS;=0A=
}=0A=
=0A=
* msCopyLine() *=0A=
* *=0A=
* Copy a lineObj, using msCopyPoint() *=0A=
int msCopyLine(lineObj *dst, lineObj *src) {=0A=
=0A=
int i;=0A=
=0A=
dst->numpoints =3D src->numpoints;=0A=
for (i =3D 0; i < dst->numpoints; i++) {=0A=
MS_COPYPOINT(&(dst->point[i]), &(src->point[i]));=0A=
}=0A=
=0A=
}=0A=
=0A=
* msCopyShape() *=0A=
* *=0A=
* Copy a shapeObj, using msCopyLine(), msCopyRect() *=0A=
* Not completely implemented or tested. *=0A=
/*=0A=
int msCopyShapeObj(shapeObj *dst, shapeObj *src) {=0A=
int i;=0A=
copyProperty(&(dst->numlines), &(src->numlines), sizeof(int));=0A=
for (i =3D 0; i < dst->numlines; i++) {=0A=
msCopyLine(&(dst->line[i]), &(src->line[i]));=0A=
}=0A=
msCopyRect(&(dst->bounds), &(src->bounds));=0A=
copyProperty(&(dst->type), &(src->type), sizeof(int));=0A=
copyProperty(&(dst->index), &(src->index), sizeof(long));=0A=
copyProperty(&(dst->tileindex), &(src->tileindex), sizeof(int));=0A=
copyProperty(&(dst->classindex), &(src->classindex), sizeof(int));=0A=
copyStringPropertyRealloc(&(dst->text), src->text);=0A=
copyProperty(&(dst->numvalues), &(src->numvalues), sizeof(int));=0A=
for (i =3D 0; i < dst->numvalues; i++) {=0A=
copyStringPropertyRealloc(&(dst->values[i]), src->values[i]);=0A=
}=0A=
=0A=
return(0);=0A=
}=0A=
*/=0A=
=0A=
* msCopyItem() *=0A=
* *=0A=
* Copy an itemObj *=0A=
=0A=
int msCopyItem(itemObj *dst, itemObj *src) {=0A=
=0A=
MS_COPYSTRING(dst->name, src->name);=0A=
MS_COPYSTELEM(type);=0A=
MS_COPYSTELEM(index);=0A=
MS_COPYSTELEM(size);=0A=
MS_COPYSTELEM(numdecimals);=0A=
=0A=
}=0A=
=0A=
* msCopyHashTable() *=0A=
* *=0A=
* Copy a hashTableObj, using msInsertHashTable() *=0A=
=0A=
int msCopyHashTable(hashTableObj dst, hashTableObj src) {=0A=
const char *key=3DNULL;=0A=
while (1) {=0A=
key =3D msNextKeyFromHashTable(src, key);=0A=
if (!key) =0A=
break;=0A=
else =0A=
msInsertHashTable(dst, key, msLookupHashTable(src, key));=0A=
}=0A=
}=0A=
=0A=
* msCopyFontSet() *=0A=
* *=0A=
* Copy a fontSetObj, using msCreateHashTable() and msCopyHashTable() *=0A=
=0A=
int msCopyFontSet(fontSetObj *dst, fontSetObj *src, mapObj *map)=0A=
{=0A=
=0A=
MS_COPYSTRING(dst->filename, src->filename);=0A=
MS_COPYSTELEM(numfonts);=0A=
if (src->fonts) {=0A=
if (!dst->fonts)=0A=
dst->fonts =3D msCreateHashTable();=0A=
if (msCopyHashTable(dst->fonts, src->fonts) !=3D MS_SUCCESS)=0A=
}=0A=
=0A=
dst->map =3D map;=0A=
=0A=
}=0A=
=0A=
* msCopyExpression( *=0A=
* *=0A=
* Copy an expressionObj, but only its string and type *=0A=
=0A=
int msCopyExpression(expressionObj *dst, expressionObj *src)=0A=
{=0A=
MS_COPYSTRING(dst->string, src->string);=0A=
dst->compiled =3D MS_FALSE;=0A=
=0A=
}=0A=
=0A=
* msCopyJoin() *=0A=
* *=0A=
* Copy a joinObj *=0A=
=0A=
int msCopyJoin(joinObj *dst, joinObj *src)=0A=
{=0A=
int i;=0A=
=0A=
// not sure it makes sense to copy the values (or the items for that =
matter) since=0A=
// since they are runtime additions to the mapfile, probably should =
be NULL with numitems=3D0=0A=
MS_COPYSTELEM(numitems);=0A=
for (i =3D 0; i < dst->numitems; i++) {=0A=
MS_COPYSTRING(dst->items[i], src->items[i]);=0A=
MS_COPYSTRING(dst->values[i], src->values[i]); =0A=
}=0A=
=0A=
MS_COPYSTRING(dst->table, src->table);=0A=
MS_COPYSTRING(dst->from, src->from);=0A=
MS_COPYSTRING(dst->to, src->to);=0A=
MS_COPYSTRING(dst->header, src->header);=0A=
#ifndef __cplusplus=0A=
MS_COPYSTRING(dst->template, src->template);=0A=
#else=0A=
MS_COPYSTRING(dst->_template, src->_template);=0A=
#endif=0A=
MS_COPYSTRING(dst->footer, src->footer);=0A=
dst->type =3D src->type;=0A=
MS_COPYSTRING(dst->connection, src->connection);=0A=
=0A=
MS_COPYSTELEM(connectiontype);=0A=
=0A=
// TODO: need to handle joininfo (probably should be just set to =
NULL)=0A=
dst->joininfo =3D NULL;=0A=
=0A=
}=0A=
=0A=
* msCopyQueryMap() *=0A=
* *=0A=
* Copy a queryMapObj, using msCopyColor() *=0A=
=0A=
int msCopyQueryMap(queryMapObj *dst, queryMapObj *src) =0A=
{=0A=
MS_COPYSTELEM(height);=0A=
MS_COPYSTELEM(width);=0A=
MS_COPYSTELEM(status);=0A=
MS_COPYSTELEM(style);=0A=
MS_COPYCOLOR(&(dst->color), &(src->color));=0A=
=0A=
}=0A=
=0A=
* msCopyLabel() *=0A=
* *=0A=
* Copy a labelObj, using msCopyColor() *=0A=
=0A=
int msCopyLabel(labelObj *dst, labelObj *src) =0A=
{=0A=
=0A=
MS_COPYSTRING(dst->font, src->font);=0A=
=0A=
MS_COPYCOLOR(&(dst->outlinecolor), &(src->outlinecolor));=0A=
MS_COPYCOLOR(&(dst->shadowcolor), &(src->shadowcolor));=0A=
=0A=
MS_COPYSTELEM(shadowsizex);=0A=
MS_COPYSTELEM(shadowsizey);=0A=
=0A=
MS_COPYCOLOR(&(dst->backgroundcolor), &(src->backgroundcolor));=0A=
MS_COPYCOLOR(&(dst->backgroundshadowcolor), =
&(src->backgroundshadowcolor));=0A=
=0A=
MS_COPYSTELEM(backgroundshadowsizex);=0A=
MS_COPYSTELEM(backgroundshadowsizey);=0A=
MS_COPYSTELEM(sizescaled);=0A=
MS_COPYSTELEM(minsize);=0A=
MS_COPYSTELEM(maxsize);=0A=
MS_COPYSTELEM(position);=0A=
MS_COPYSTELEM(offsetx);=0A=
MS_COPYSTELEM(offsety);=0A=
MS_COPYSTELEM(angle);=0A=
MS_COPYSTELEM(autoangle);=0A=
MS_COPYSTELEM(buffer);=0A=
MS_COPYSTELEM(antialias);=0A=
MS_COPYSTELEM(wrap);=0A=
MS_COPYSTELEM(minfeaturesize);=0A=
=0A=
MS_COPYSTELEM(autominfeaturesize);=0A=
=0A=
MS_COPYSTELEM(mindistance);=0A=
MS_COPYSTELEM(partials);=0A=
MS_COPYSTELEM(force);=0A=
=0A=
}=0A=
=0A=
* msCopyWeb() *=0A=
* *=0A=
* Copy webObj, using msCopyRect(), msCreateHashTable(), and *=0A=
=0A=
int msCopyWeb(webObj *dst, webObj *src, mapObj *map) =0A=
{=0A=
=0A=
MS_COPYSTRING(dst->log, src->log);=0A=
MS_COPYSTRING(dst->imagepath, src->imagepath);=0A=
MS_COPYSTRING(dst->imageurl, src->imageurl);=0A=
#else=0A=
#endif=0A=
MS_COPYSTRING(dst->empty, src->empty);=0A=
MS_COPYSTRING(dst->error, src->error);=0A=
=0A=
MS_COPYRECT(&(dst->extent), &(src->extent));=0A=
=0A=
MS_COPYSTELEM(minscale);=0A=
MS_COPYSTELEM(maxscale);=0A=
MS_COPYSTRING(dst->mintemplate, src->mintemplate);=0A=
MS_COPYSTRING(dst->maxtemplate, src->maxtemplate);=0A=
=0A=
if (src->metadata) {=0A=
dst->metadata =3D msCreateHashTable();=0A=
if (msCopyHashTable((dst->metadata), (src->metadata)) !=3D =
MS_SUCCESS)=0A=
}=0A=
=0A=
return MS_SUCCESS ;=0A=
}=0A=
=0A=
* msCopyStyle() *=0A=
* *=0A=
* Copy a styleObj, using msCopyColor() *=0A=
=0A=
int msCopyStyle(styleObj *dst, styleObj *src) =0A=
{=0A=
=0A=
MS_COPYCOLOR(&(dst->outlinecolor),&(src->outlinecolor));=0A=
MS_COPYSTRING(dst->symbolname, src->symbolname);=0A=
=0A=
MS_COPYSTELEM(symbol);=0A=
MS_COPYSTELEM(isachild);=0A=
=0A=
}=0A=
=0A=
* msCopyClass() *=0A=
* *=0A=
* Copy a classObj, using msCopyExpression(), msCopyStyle(), *=0A=
* msCopyLabel(), msCreateHashTable(), msCopyHashTable() *=0A=
=0A=
int msCopyClass(classObj *dst, classObj *src, layerObj *layer) =0A=
{=0A=
int i, return_value;=0A=
=0A=
return_value =3D =
msCopyExpression(&(dst->expression),&(src->expression));=0A=
if (return_value !=3D MS_SUCCESS) {=0A=
msSetError(MS_MEMERR, "Failed to copy expression.", =
"msCopyClass()");=0A=
}=0A=
=0A=
MS_COPYSTELEM(numstyles);=0A=
=0A=
for (i =3D 0; i < dst->numstyles; i++) {=0A=
if (msCopyStyle(&(dst->styles[i]), &(src->styles[i])) !=3D =
MS_SUCCESS) {=0A=
msSetError(MS_MEMERR, "Failed to copy style.", =
}=0A=
}=0A=
=0A=
if (msCopyLabel(&(dst->label), &(src->label)) !=3D MS_SUCCESS) {=0A=
msSetError(MS_MEMERR, "Failed to copy label.", "msCopyClass()");=0A=
}=0A=
=0A=
MS_COPYSTRING(dst->keyimage, src->keyimage);=0A=
MS_COPYSTRING(dst->title, src->title);=0A=
=0A=
if (msCopyExpression(&(dst->text), &(src->text)) !=3D MS_SUCCESS) {=0A=
msSetError(MS_MEMERR, "Failed to copy text.", "msCopyClass()");=0A=
}=0A=
=0A=
#else=0A=
#endif=0A=
=0A=
if (src->metadata !=3D NULL) {=0A=
msCopyHashTable(dst->metadata, src->metadata);=0A=
}=0A=
=0A=
MS_COPYSTELEM(layer);=0A=
MS_COPYSTELEM(debug);=0A=
=0A=
}=0A=
=0A=
* msCopyLabelCacheMember() *=0A=
* *=0A=
* Copy a labelCacheMemberObj using msCopyStyle(), msCopyPoint() *=0A=
* *=0A=
* Note: since it seems most users will want to clone maps rather than *=0A=
* make exact copies, this method might not get much use. *=0A=
=0A=
int msCopyLabelCacheMember(labelCacheMemberObj *dst,=0A=
labelCacheMemberObj *src)=0A=
{=0A=
int i;=0A=
=0A=
MS_COPYSTELEM(featuresize);=0A=
=0A=
msCopyStyle(&(dst->styles[i]), &(src->styles[i]));=0A=
}=0A=
=0A=
msCopyLabel(&(dst->label), &(src->label));=0A=
MS_COPYSTELEM(layerindex);=0A=
MS_COPYSTELEM(classindex);=0A=
MS_COPYSTELEM(tileindex);=0A=
MS_COPYSTELEM(shapeindex);=0A=
MS_COPYPOINT(&(dst->point), &(src->point));=0A=
//msCopyShape(&(dst->poly), &(src->poly));=0A=
=0A=
}=0A=
=0A=
* msCopyMarkerCacheMember() *=0A=
* *=0A=
* Copy a markerCacheMemberObj *=0A=
=0A=
int msCopyMarkerCacheMember(markerCacheMemberObj *dst,=0A=
markerCacheMemberObj *src) =0A=
{ =0A=
MS_COPYSTELEM(id);=0A=
=0A=
}=0A=
=0A=
* msCopyLabelCache() *=0A=
=0A=
int msCopyLabelCache(labelCacheObj *dst, labelCacheObj *src) =0A=
{=0A=
int i;=0A=
MS_COPYSTELEM(numlabels);=0A=
for (i =3D 0; i < dst->numlabels; i++) {=0A=
msCopyLabelCacheMember(&(dst->labels[i]), &(src->labels[i]));=0A=
}=0A=
MS_COPYSTELEM(cachesize);=0A=
MS_COPYSTELEM(nummarkers);=0A=
for (i =3D 0; i < dst->nummarkers; i++) {=0A=
msCopyMarkerCacheMember(&(dst->markers[i]), &(src->markers[i]));=0A=
}=0A=
=0A=
MS_COPYSTELEM(markercachesize);=0A=
=0A=
}=0A=
=0A=
* *=0A=
=0A=
int msCopyResultCacheMember(resultCacheMemberObj *dst,=0A=
resultCacheMemberObj *src)=0A=
{=0A=
=0A=
}=0A=
=0A=
* msCopyResultCache() *=0A=
=0A=
int msCopyResultCache(resultCacheObj *dst, resultCacheObj *src) =0A=
{=0A=
int i;=0A=
MS_COPYSTELEM(numresults);=0A=
for (i =3D 0; i < dst->numresults; i++) {=0A=
msCopyResultCacheMember(&(dst->results[i]), &(src->results[i]));=0A=
}=0A=
MS_COPYRECT(&(dst->bounds), &(src->bounds));=0A=
=0A=
}=0A=
=0A=
* msCopyReferenceMap() *=0A=
* *=0A=
* Copy a referenceMapObj using mapfile.c:initReferenceMap(), *=0A=
* msCopyRect(), msCopyColor() *=0A=
=0A=
int msCopyReferenceMap(referenceMapObj *dst, referenceMapObj *src,=0A=
mapObj *map)=0A=
{=0A=
=0A=
initReferenceMap(dst);=0A=
=0A=
=0A=
=0A=
=0A=
MS_COPYSTRING(dst->image, src->image);=0A=
=0A=
MS_COPYSTELEM(marker);=0A=
MS_COPYSTRING(dst->markername, src->markername);=0A=
MS_COPYSTELEM(markersize);=0A=
MS_COPYSTELEM(minboxsize);=0A=
MS_COPYSTELEM(maxboxsize);=0A=
=0A=
}=0A=
=0A=
* msCopyScalebar() *=0A=
* *=0A=
* Copy a scalebarObj, using initScalebar(), msCopyColor(), *=0A=
* and msCopyLabel() *=0A=
=0A=
int msCopyScalebar(scalebarObj *dst, scalebarObj *src)=0A=
{=0A=
=0A=
initScalebar(dst);=0A=
=0A=
MS_COPYCOLOR(&(dst->imagecolor), &(src->imagecolor));=0A=
MS_COPYSTELEM(intervals);=0A=
=0A=
msSetError(MS_MEMERR, "Failed to copy =
label.","msCopyScalebar()");=0A=
}=0A=
=0A=
=0A=
=0A=
MS_COPYSTELEM(units);=0A=
MS_COPYSTELEM(transparent);=0A=
MS_COPYSTELEM(interlace);=0A=
MS_COPYSTELEM(postlabelcache);=0A=
=0A=
}=0A=
=0A=
* msCopyLegend() *=0A=
* *=0A=
* Copy a legendObj, using msCopyColor() *=0A=
=0A=
int msCopyLegend(legendObj *dst, legendObj *src, mapObj *map)=0A=
{=0A=
int return_value;=0A=
=0A=
=0A=
return_value =3D msCopyLabel(&(dst->label), &(src->label));=0A=
msSetError(MS_MEMERR, "Failed to copy label.",=0A=
"msCopyLegend()");=0A=
}=0A=
=0A=
MS_COPYSTELEM(keysizex);=0A=
MS_COPYSTELEM(keysizey);=0A=
MS_COPYSTELEM(keyspacingx);=0A=
MS_COPYSTELEM(keyspacingy);=0A=
=0A=
=0A=
=0A=
#else=0A=
#endif=0A=
=0A=
}=0A=
=0A=
* msCopyLayer() *=0A=
* *=0A=
* Copy a layerObj, using mapfile.c:initClass(), msCopyClass(), *=0A=
* msCopyColor(), msCopyProjection(), msSHPOpenFile(), *=0A=
* msCreateHashTable(), msCopyHashTable(), msCopyExpression() *=0A=
* *=0A=
* As it stands, we are not copying a layer's resultcache *=0A=
=0A=
int msCopyLayer(layerObj *dst, layerObj *src)=0A=
{=0A=
featureListNodeObjPtr current;=0A=
// char szPath[MS_MAXPATHLEN];=0A=
=0A=
MS_COPYSTRING(dst->classitem, src->classitem);=0A=
=0A=
MS_COPYSTELEM(classitemindex);=0A=
MS_COPYSTELEM(numclasses);=0A=
=0A=
for (i =3D 0; i < dst->numclasses; i++) {=0A=
initClass(&(dst->class[i]));=0A=
=0A=
return_value =3D msCopyClass(&(dst->class[i]), &(src->class[i]), =
dst);=0A=
msSetError(MS_MEMERR, "Failed to copy class.", =
"msCopyLayer()");=0A=
}=0A=
#else=0A=
initClass(&(dst->_class[i]));=0A=
=0A=
return_value =3D msCopyClass(&(dst->_class[i]), =
&(src->_class[i]), dst);=0A=
msSetError(MS_MEMERR, "Failed to copy _class.", =
}=0A=
#endif=0A=
}=0A=
#else=0A=
#endif=0A=
=0A=
//copyProperty(&(dst->resultcache), &(src->resultcache),=0A=
//sizeof(resultCacheObj *));=0A=
//=0A=
MS_COPYSTRING(dst->name, src->name); =0A=
MS_COPYSTRING(dst->group, src->group); =0A=
MS_COPYSTRING(dst->data, src->data); =0A=
=0A=
MS_COPYSTELEM(annotate);=0A=
MS_COPYSTELEM(tolerance);=0A=
MS_COPYSTELEM(toleranceunits);=0A=
MS_COPYSTELEM(symbolscale);=0A=
MS_COPYSTELEM(scalefactor);=0A=
=0A=
MS_COPYSTELEM(labelminscale);=0A=
MS_COPYSTELEM(labelmaxscale);=0A=
=0A=
MS_COPYSTELEM(sizeunits);=0A=
MS_COPYSTELEM(maxfeatures);=0A=
=0A=
MS_COPYCOLOR(&(dst->offsite), &(src->offsite));=0A=
=0A=
MS_COPYSTELEM(transform);=0A=
MS_COPYSTELEM(labelcache);=0A=
MS_COPYSTELEM(postlabelcache); =0A=
=0A=
MS_COPYSTRING(dst->labelitem, src->labelitem);=0A=
MS_COPYSTRING(dst->labelsizeitem, src->labelsizeitem);=0A=
MS_COPYSTRING(dst->labelangleitem, src->labelangleitem);=0A=
=0A=
MS_COPYSTELEM(labelitemindex);=0A=
MS_COPYSTELEM(labelsizeitemindex);=0A=
MS_COPYSTELEM(labelangleitemindex);=0A=
=0A=
MS_COPYSTRING(dst->tileitem, src->tileitem);=0A=
MS_COPYSTELEM(tileitemindex);=0A=
=0A=
MS_COPYSTRING(dst->tileindex, src->tileindex); =0A=
=0A=
return_value =3D =
msCopyProjection(&(dst->projection),&(src->projection));=0A=
msSetError(MS_MEMERR, "Failed to copy projection.", =
}=0A=
=0A=
MS_COPYSTELEM(project); =0A=
MS_COPYSTELEM(units); =0A=
=0A=
current =3D src->features;=0A=
while(current !=3D NULL) {=0A=
insertFeatureList(&(dst->features), &(current->shape));=0A=
current =3D current->next;=0A=
}=0A=
=0A=
MS_COPYSTELEM(sameconnection);=0A=
=0A=
//msSHPOpenFile(&(dst->shpfile), "rb", msBuildPath(szPath, =
src->map->shapepath, src->data));=0A=
//msSHPOpenFile(&(dst->tileshpfile), "rb", msBuildPath(szPath, =
src->map->shapepath, src->tileindex));=0A=
=0A=
MS_COPYSTELEM(layerinfo);=0A=
MS_COPYSTELEM(ogrlayerinfo); =0A=
MS_COPYSTELEM(wfslayerinfo);=0A=
=0A=
}=0A=
=0A=
MS_COPYSTELEM(iteminfo);=0A=
=0A=
return_value =3D msCopyExpression(&(dst->filter), &(src->filter));=0A=
msSetError(MS_MEMERR, "Failed to copy filter.", "msCopyLayer()");=0A=
}=0A=
=0A=
MS_COPYSTRING(dst->filteritem, src->filteritem);=0A=
MS_COPYSTELEM(filteritemindex);=0A=
=0A=
MS_COPYSTRING(dst->styleitem, src->styleitem); =0A=
MS_COPYSTELEM(styleitemindex);=0A=
=0A=
MS_COPYSTRING(dst->requires, src->requires); =0A=
MS_COPYSTRING(dst->labelrequires, src->labelrequires);=0A=
=0A=
msCopyHashTable((dst->metadata), (src->metadata));=0A=
}=0A=
=0A=
MS_COPYSTELEM(transparency);=0A=
MS_COPYSTELEM(dump);=0A=
MS_COPYSTELEM(numprocessing);=0A=
=0A=
for (i =3D 0; i < dst->numprocessing; i++) {=0A=
MS_COPYSTRING(dst->processing[i], src->processing[i]);=0A=
}=0A=
=0A=
MS_COPYSTELEM(numjoins);=0A=
=0A=
return_value =3D msCopyJoin(&(dst->joins[i]), &(src->joins[i]));=0A=
if (return_value !=3D MS_SUCCESS)=0A=
}=0A=
=0A=
}=0A=
=0A=
* msCopySymbol() *=0A=
* *=0A=
* Copy a symbolObj, using mapfile.c:initSymbol(), msCopyPoint() *=0A=
* gdImageCreate(), gdImageCopy() *=0A=
=0A=
int msCopySymbol(symbolObj *dst, symbolObj *src, mapObj *map) =0A=
{=0A=
int i;=0A=
=0A=
initSymbol(dst);=0A=
=0A=
MS_COPYSTELEM(inmapfile);=0A=
MS_COPYSTELEM(sizex);=0A=
MS_COPYSTELEM(sizey);=0A=
=0A=
for (i=3D0; i < MS_MAXVECTORPOINTS; i++) {=0A=
MS_COPYPOINT(&(dst->points[i]), &(src->points[i]));=0A=
}=0A=
=0A=
MS_COPYSTELEM(numpoints);=0A=
MS_COPYSTELEM(filled);=0A=
MS_COPYSTELEM(stylelength);=0A=
=0A=
memcpy(&(dst->style), &(src->style), sizeof(int) * =
MS_MAXSTYLELENGTH);=0A=
=0A=
//gdImagePtr img;=0A=
if (src->img) {=0A=
if (dst->img) {=0A=
gdFree(dst->img);=0A=
}=0A=
dst->img =3D gdImageCreate(src->img->sx, src->img->sy);=0A=
gdImageCopy(dst->img, src->img, 0, 0, 0, 0,=0A=
}=0A=
=0A=
=0A=
MS_COPYSTELEM(transparentcolor);=0A=
=0A=
MS_COPYSTRING(dst->character, src->character);=0A=
MS_COPYSTELEM(gap);=0A=
MS_COPYSTELEM(linecap);=0A=
MS_COPYSTELEM(linejoin);=0A=
=0A=
MS_COPYSTELEM(linejoinmaxsize);=0A=
=0A=
} =0A=
=0A=
* msCopySymbolSet() *=0A=
* *=0A=
* Copy a symbolSetObj using msCopyFontSet(), msCopySymbol() *=0A=
=0A=
int msCopySymbolSet(symbolSetObj *dst, symbolSetObj *src, mapObj *map)=0A=
{=0A=
=0A=
MS_COPYSTELEM(map);=0A=
=0A=
dst->fontset =3D &(map->fontset);=0A=
=0A=
/*if (msCopyFontSet(dst->fontset, src->fontset, map) !=3D =
MS_SUCCESS) {=0A=
msSetError(MS_MEMERR,"Failed to copy fontset.","msCopySymbolSet()");=0A=
return(MS_FAILURE);=0A=
}*/=0A=
=0A=
MS_COPYSTELEM(numsymbols);=0A=
=0A=
for (i =3D 0; i < dst->numsymbols; i++) {=0A=
return_value =3D msCopySymbol(&(dst->symbol[i]), =
&(src->symbol[i]), map);=0A=
msSetError(MS_MEMERR,"Failed to copy =
symbol.","msCopySymbolSet()");=0A=
}=0A=
}=0A=
#if 0=0A=
/* No need to copy the imagecache cause the images have diferent =
pointers=0A=
* Perhaps the image reference can be used so that images don't get =
copyied=0A=
*/=0A=
MS_COPYSTELEM(imagecachesize);=0A=
=0A=
// I have a feeling that the code below is not quite right - Sean=0A=
memcpy(&(dst->imagecache), &(src->imagecache), sizeof(struct =
imageCacheObj));=0A=
#endif=0A=
}=0A=
=0A=
* msCopyMap() *=0A=
* *=0A=
* Copy a mapObj, using mapfile.c:initLayer(), msCopyLayer(), *=0A=
=0A=
* msCopyLegend(), msCopyScalebar(), msCopyProjection() *=0A=
* msCopyOutputFormat(), msCopyWeb(), msCopyReferenceMap() *=0A=
=0A=
int msCopyMap(mapObj *dst, mapObj *src)=0A=
{=0A=
outputFormatObj *format;=0A=
=0A=
MS_COPYSTELEM(numlayers);=0A=
=0A=
for (i =3D 0; i < dst->numlayers; i++) {=0A=
initLayer(&(dst->layers[i]), dst);=0A=
=0A=
return_value =3D msCopyLayer(&(dst->layers[i]), =
&(src->layers[i]));=0A=
msSetError(MS_MEMERR, "Failed to copy layer.", =
"msCopyMap()");=0A=
}=0A=
}=0A=
=0A=
return_value =3D msCopyFontSet(&(dst->fontset), &(src->fontset), =
dst);=0A=
msSetError(MS_MEMERR, "Failed to copy fontset.", "msCopyMap()");=0A=
}=0A=
=0A=
return_value =3D msCopySymbolSet(&(dst->symbolset), =
&(src->symbolset), dst);=0A=
if(return_value !=3D MS_SUCCESS) {=0A=
msSetError(MS_MEMERR, "Failed to copy symbolset.", =
"msCopyMap()");=0A=
}=0A=
=0A=
//msCopyLabelCache(&(dst->labelcache), &(src->labelcache));=0A=
MS_COPYSTELEM(imagequality);=0A=
=0A=
=0A=
MS_COPYSTELEM(cellsize);=0A=
MS_COPYSTELEM(scale);=0A=
MS_COPYSTELEM(resolution);=0A=
MS_COPYSTRING(dst->shapepath, src->shapepath); =0A=
MS_COPYSTRING(dst->mappath, src->mappath); =0A=
=0A=
=0A=
/* clear existing destination format list */=0A=
if( dst->outputformat && --dst->outputformat->refcount < 1 )=0A=
{=0A=
msFreeOutputFormat( dst->outputformat );=0A=
dst->outputformat =3D NULL;=0A=
}=0A=
=0A=
for(i=3D0; i < dst->numoutputformats; i++ ) {=0A=
if( --dst->outputformatlist[i]->refcount < 1 )=0A=
msFreeOutputFormat( dst->outputformatlist[i] );=0A=
}=0A=
if( dst->outputformatlist !=3D NULL )=0A=
msFree( dst->outputformatlist );=0A=
dst->outputformatlist =3D NULL;=0A=
dst->numoutputformats =3D 0;=0A=
=0A=
for (i =3D 0; i < src->numoutputformats; i++)=0A=
msAppendOutputFormat( dst, =0A=
msCloneOutputFormat( src->outputformatlist[i]) );=0A=
=0A=
// set the active output format=0A=
MS_COPYSTRING(dst->imagetype, src->imagetype); =0A=
format =3D msSelectOutputFormat( dst, dst->imagetype );=0A=
msApplyOutputFormat(&(dst->outputformat), format, MS_NOOVERRIDE, =0A=
MS_NOOVERRIDE, MS_NOOVERRIDE );=0A=
=0A=
return_value =3D =
"msCopyMap()");=0A=
}=0A=
=0A=
/*return_value =3D msCopyProjection(&(dst->latlon), &(src->latlon));=0A=
msSetError(MS_MEMERR, "Failed to copy latlon.", "msCopyMap()");=0A=
}*/=0A=
=0A=
return_value =3D =
msCopyReferenceMap(&(dst->reference),&(src->reference),=0A=
dst);=0A=
msSetError(MS_MEMERR, "Failed to copy reference.", =
"msCopyMap()");=0A=
}=0A=
=0A=
return_value =3D msCopyScalebar(&(dst->scalebar), &(src->scalebar));=0A=
msSetError(MS_MEMERR, "Failed to copy scalebar.", "msCopyMap()");=0A=
}=0A=
=0A=
return_value =3D msCopyLegend(&(dst->legend), &(src->legend),dst);=0A=
msSetError(MS_MEMERR, "Failed to copy legend.", "msCopyMap()");=0A=
}=0A=
=0A=
return_value =3D msCopyQueryMap(&(dst->querymap), &(src->querymap));=0A=
msSetError(MS_MEMERR, "Failed to copy querymap.", "msCopyMap()");=0A=
}=0A=
=0A=
return_value =3D msCopyWeb(&(dst->web), &(src->web), dst);=0A=
msSetError(MS_MEMERR, "Failed to copy web.", "msCopyMap()");=0A=
}=0A=
=0A=
MS_COPYSTELEM(layerorder[i]);=0A=
}=0A=
MS_COPYSTRING(dst->datapattern, src->datapattern);=0A=
MS_COPYSTRING(dst->templatepattern, src->templatepattern); =0A=
=0A=
if( msCopyHashTable( dst->configoptions, src->configoptions ) !=3D =
MS_SUCCESS )=0A=
=0A=
}=0A=
=0A=
------=_NextPart_001_007B_01C446FE.F95F5AF0--
Content-Type: application/x-pkcs7-signature;
name="smime.p7s"
Content-Transfer-Encoding: base64
filename="smime.p7s"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------=_NextPart_000_007A_01C446FE.F95F5AF0--
