mapwms.c small quick quick fix
Daniel Morissette dmorissette at DMSOLUTIONS.CA
Wed Nov 3 23:24:18 EST 2004
Kralidis,Tom [Burlington] wrote:
> Hi,
> mapwms.c, when printing out MetadataURL via msOWSPrintURLType(), forgets
> to print out the xlink:type="simple" attribute, as per other elements of
> the same type.
> ...Can someone commit this to line 1217 in mapwms.c?  Same sort of thing
> as in mapwms.c line 1231.
> I'm not sure whether I should post this to bugzilla -- it's pretty
> trivial.
Yes, even the most trivial bug deserves a home in the database since it
affects functionality, and even if it sounds trivial at first we may
find later on that the impacts or side-effects are not that trivial.
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
