build warnings in source code
Frank Warmerdam warmerdam at POBOX.COM
Thu Nov 4 16:55:59 EST 2004
Kralidis,Tom [Burlington] wrote:
> maplegend.c: In function `msDrawLegend':
> maplegend.c:233: warning: unused variable `empty_legend'
Fixed.
> mapwms.c: In function `msDumpLayer':
> mapwms.c:1086: warning: `pszMetadataName' might be used uninitialized in
> this function
I filed a bug on this witht he WMS maintainers.  The logic in this
area looks hosed to me, and I think pszMetadataName would be used
uninitialized.
> mapprojhack.c:111: warning: missing braces around initializer
> mapprojhack.c:111: warning: (near initialization for `pj_units_copy[0]')
My fault, but I won't fix it.  To yucky to add all the extra braces.  Eventually
I can get rid of this when everyone is using PROJ 4.4.9 or newer.
> mapdraw.c: In function `msDrawMap':
> mapdraw.c:386: warning: implicit declaration of function
> `msDrawWMSLayerPDF'
Fixed.
> mappdf.c: In function `msSaveImagePDF':
> mappdf.c:1208: warning: unused variable `out'
> mappdf.c: In function `msDrawTextPDF':
> mappdf.c:1337: warning: assignment makes integer from pointer without a
> cast
Fixed.
I don't build with pdf currently, so if someone else who does could verify
the pdf changes still build clean that would be helpful.  I can break
stuff with the smallest simpliest changes sometimes.
> maptime.c: In function `msStrptime':
> maptime.c:157: warning: implicit declaration of function `strptime'
> maptime.c:157: warning: return makes pointer from integer without a cast
I'm not touching this.
> mapwcs.c: In function `msWCSDispatch':
> mapwcs.c:1087: warning: unused variable `status'
fixed.
> shp2pdf.c: In function `main':
> shp2pdf.c:76: warning: unused variable `img'
> shp2pdf.c:83: warning: unused variable `pdf'
> shp2pdf.c:88: warning: unused variable `MapScaleFactor'
> shp2pdf.c:89: warning: unused variable `MapPixelSize'
fixed.
> mapserv.c: In function `main':
> mapserv.c:1051: warning: unused variable `sname'
fixed.
Ironically I had just done a "logged" build before your email came through
so I could clean up some of the warnings.
Best regards,
