WMS server time tests and issues
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Mon Nov 8 14:31:35 EST 2004
I've been testing this out on latest CVS. Observations:
- OS: FC2
Linux devgeo.cciw.ca 2.6.5-1.358smp #1 SMP Sat May 8 09:25:36 EDT 2004
i686 i686 i386 GNU/Linux
- httpd: Apache 2.0.49
I constructed a dummy .shp/.shx/.dbf with 4 columns 3 records with a
timefield.
Here's a dump of what the shapefile is:
stid | lat | lon | obsdate
tom | 45.412766 | -71.920082 | 2004-10-12
bob | 45.399400 | -75.704200 | 2003-09-30
joe | 55.399400 | -95.704200 | 2002-03-17
...and here's the time defines in LAYER/METADATA in mapfile:
"wms_timeextent" "2002-03-17/2004-10-12"
"wms_timedefault" "2003-09-30"
"wms_timeitem" "obsdate"
...and here's my tests:
Single value:
http://devgeo.cciw.ca/cgi-bin/mapserv/ecows?version=1.1.1&service=WMS&re
quest=GetMap&layers=obs&format=image/gif&srs=EPSG:4326&transparent=TRUE&
exceptions=application%2Fvnd.ogc.se_inimage&bbox=-140.243500,28.606653,-
51.243500,81.998653&width=500&height=300&time=2004-10-12-T00:00:00&style
s=default
Result: no problem, as expected
Multple value:
51.243500,81.998653&width=500&height=300&time=2004-10-12-T00:00:00,2003-
09-30-T00:00:00&styles=default
Single range:
51.243500,81.998653&width=500&height=300&time=2002-03-17-T00:00:00/2004-
10-12-T00:00:00&styles=default
Result: when the start time or end time is out of range of the default.
For example, if you change the start year to 2001, only one point shows
up:
51.243500,81.998653&width=500&height=300&time=2001-03-17-T00:00:00/2004-
...so it looks like the default is returned when the range given is
outside the range defined in "wms_timeextent".
Is this the expected behaviour? As a WMS client, I would expect that
temporal queries would return everything inside two given dates, just
like a spatial query does.
..Tom
