WMS server time tests and issues
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Mon Nov 8 18:36:42 EST 2004
Kralidis,Tom [Burlington] wrote:
>>-----Original Message-----
>>From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
>>Sent: Monday, 08 November, 2004 16:00
>>To: Kralidis,Tom [Burlington]
>>Cc: MAPSERVER-DEV at LISTS.UMN.EDU
>>Subject: Re: [UMN_MAPSERVER-DEV] WMS server time tests and issues
>>>Hi,
>>>I've been testing this out on latest CVS. Observations:
>>>- OS: FC2
>>>Linux devgeo.cciw.ca 2.6.5-1.358smp #1 SMP Sat May 8
>>09:25:36 EDT 2004
>>>i686 i686 i386 GNU/Linux
>>>- httpd: Apache 2.0.49
>>>I constructed a dummy .shp/.shx/.dbf with 4 columns 3
>>records with a
>>>timefield.
>>>Here's a dump of what the shapefile is:
>>>stid | lat | lon | obsdate
>>>tom | 45.412766 | -71.920082 | 2004-10-12
>>>bob | 45.399400 | -75.704200 | 2003-09-30
>>>joe | 55.399400 | -95.704200 | 2002-03-17
>>>...and here's the time defines in LAYER/METADATA in mapfile:
>>> "wms_timeextent" "2002-03-17/2004-10-12"
>>> "wms_timedefault" "2003-09-30"
>>> "wms_timeitem" "obsdate"
>>>...and here's my tests:
>>>Single value:
>>http://devgeo.cciw.ca/cgi-bin/mapserv/ecows?version=1.1.1&service=WMS&
>>>re
>>quest=GetMap&layers=obs&format=image/gif&srs=EPSG:4326&transpa
>>rent=TRUE&
>>exceptions=application%2Fvnd.ogc.se_inimage&bbox=-140.243500,2
> 8.606653,-
>>51.243500,81.998653&width=500&height=300&time=2004-10-12-T00:0
>>0:00&style
>>>s=default
>>>Result: no problem, as expected
>>>Multple value:
>>>re
>>rent=TRUE&
> 8.606653,-
>>0:00,2003-
>>>09-30-T00:00:00&styles=default
>>>Single range:
>>>re
>>rent=TRUE&
> 8.606653,-
>>51.243500,81.998653&width=500&height=300&time=2002-03-17-T00:0
>>0:00/2004-
>>>10-12-T00:00:00&styles=default
>>>Result: when the start time or end time is out of range of the
>>>default. For example, if you change the start year to 2001,
>>only one
>>>point shows
>>>up:
>>>re
>>rent=TRUE&
> 8.606653,-
>>51.243500,81.998653&width=500&height=300&time=2001-03-17-T00:0
>>0:00/2004-
>>>...so it looks like the default is returned when the range given is
>>>outside the range defined in "wms_timeextent".
>>>Is this the expected behaviour? As a WMS client, I would
>>expect that
>>>temporal queries would return everything inside two given
>>dates, just
>>>like a spatial query does.
>>>..Tom
>>I think that the specs indicates that if the given values are
>>"incorrect" the server would return values for the default declared :
>>Section C5.1 (Annexe C wms 1.1.1 ):
>>" ...An OGC Web Service may declare a default for any dimension. A
>>'default' is optional but recommended. If a request does not
>>include a
>>value along this dimension, and a default has been declared, then the
>>server shall send the default value..."
>> The implementation was the interpretation of this text.
> Thanks for the clarification -- being a spec zealot I should have read
> up on this!!
> At any rate, if I comment out "wms_timedefault", and I specify:
> http://devgeo.cciw.ca/cgi-bin/mapserv/ecows?version=1.1.1&service=WMS&re
> quest=GetMap&layers=obs&format=image/gif&srs=EPSG:4326&transparent=TRUE&
> exceptions=application%2Fvnd.ogc.se_inimage&bbox=-140.243500,28.606653,-
> 51.243500,81.998653&width=500&height=300&time=2002-03-17-T00:00:00/2004-
> ...it works as expected. If I specify a range outside the time extents,
> i.e.:
> 51.243500,81.998653&width=500&height=300&time=2001-03-17-T00:00:00/2004-
> I get prompted to download image/tiff. What happens in this case?
It should normally send an exception of this nature :
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://ogc.dmsolutions.ca/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException code="InvalidDimensionValue">
msWMSApplyTime: WMS server error. Time value(s) 2003-01-01 14:10 given
is invalid or outside the time extent defined (2004-01-01/2004-02-01).
</ServiceException>
</ServiceExceptionReport>
Not sure where the image/tiff comes from.
Later,
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
