WMS server time tests and issues
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Mon Nov 8 18:52:47 EST 2004
Kralidis,Tom [Burlington] wrote:
>>-----Original Message-----
>>From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
>>Sent: Monday, 08 November, 2004 18:37
>>To: Kralidis,Tom [Burlington]
>>Cc: MAPSERVER-DEV at LISTS.UMN.EDU
>>Subject: Re: [UMN_MAPSERVER-DEV] WMS server time tests and issues
>>>>Sent: Monday, 08 November, 2004 16:00
>>>>>Hi,
>>>>>I've been testing this out on latest CVS. Observations:
>>>>>- OS: FC2
>>>>>Linux devgeo.cciw.ca 2.6.5-1.358smp #1 SMP Sat May 8
>>>>09:25:36 EDT 2004
>>>>>i686 i686 i386 GNU/Linux
>>>>>- httpd: Apache 2.0.49
>>>>>I constructed a dummy .shp/.shx/.dbf with 4 columns 3
>>>>records with a
>>>>>timefield.
>>>>>Here's a dump of what the shapefile is:
>>>>>stid | lat | lon | obsdate
>>>>>tom | 45.412766 | -71.920082 | 2004-10-12
>>>>>bob | 45.399400 | -75.704200 | 2003-09-30
>>>>>joe | 55.399400 | -95.704200 | 2002-03-17
>>>>>...and here's the time defines in LAYER/METADATA in mapfile:
>>>>> "wms_timeextent" "2002-03-17/2004-10-12"
>>>>> "wms_timedefault" "2003-09-30"
>>>>> "wms_timeitem" "obsdate"
>>>>>...and here's my tests:
>>>>>Single value:
>>>>http://devgeo.cciw.ca/cgi-bin/mapserv/ecows?version=1.1.1&se
>>rvice=WMS&
>>>>>re
>>>>quest=GetMap&layers=obs&format=image/gif&srs=EPSG:4326&transpa
>>>>rent=TRUE&
>>>>exceptions=application%2Fvnd.ogc.se_inimage&bbox=-140.243500,2
>>>8.606653,-
>>>>51.243500,81.998653&width=500&height=300&time=2004-10-12-T00:0
>>>>0:00&style
>>>>>s=default
>>>>>Result: no problem, as expected
>>>>>Multple value:
>>rvice=WMS&
>>>>>re
>>>>rent=TRUE&
>>>8.606653,-
>>>>0:00,2003-
>>>>>09-30-T00:00:00&styles=default
>>>>>Single range:
>>rvice=WMS&
>>>>>re
>>>>rent=TRUE&
>>>8.606653,-
>>>>51.243500,81.998653&width=500&height=300&time=2002-03-17-T00:0
>>>>0:00/2004-
>>>>>10-12-T00:00:00&styles=default
>>>>>Result: when the start time or end time is out of range of the
>>>>>default. For example, if you change the start year to 2001,
>>>>only one
>>>>>point shows
>>>>>up:
>>rvice=WMS&
>>>>>re
>>>>rent=TRUE&
>>>8.606653,-
>>>>51.243500,81.998653&width=500&height=300&time=2001-03-17-T00:0
>>>>0:00/2004-
>>>>>...so it looks like the default is returned when the range given is
>>>>>outside the range defined in "wms_timeextent".
>>>>>Is this the expected behaviour? As a WMS client, I would
>>>>expect that
>>>>>temporal queries would return everything inside two given
>>>>dates, just
>>>>>like a spatial query does.
>>>>>..Tom
>>>>I think that the specs indicates that if the given values are
>>>>"incorrect" the server would return values for the default
>>declared :
>>>>Section C5.1 (Annexe C wms 1.1.1 ):
>>>>" ...An OGC Web Service may declare a default for any dimension. A
>>>>'default' is optional but recommended. If a request does not
>>>>include a
>>>>value along this dimension, and a default has been
>>declared, then the
>>>>server shall send the default value..."
>>>> The implementation was the interpretation of this text.
>>>Thanks for the clarification -- being a spec zealot I
>>should have read
>>>up on this!!
>>>At any rate, if I comment out "wms_timedefault", and I specify:
>>http://devgeo.cciw.ca/cgi-bin/mapserv/ecows?version=1.1.1&service=WMS&
>>>re
>>rent=TRUE&
> 8.606653,-
>>0:00/2004-
>>>...it works as expected. If I specify a range outside the time
>>>extents,
>>>i.e.:
>>>re
>>rent=TRUE&
> 8.606653,-
>>0:00/2004-
>>>I get prompted to download image/tiff. What happens in this case?
>>It should normally send an exception of this nature :
>><?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
>><!DOCTYPE ServiceExceptionReport SYSTEM
>>"http://ogc.dmsolutions.ca/wms/1.1.1/exception_1_1_1.dtd">
>><ServiceExceptionReport version="1.1.1">
>><ServiceException code="InvalidDimensionValue">
>>msWMSApplyTime: WMS server error. Time value(s) 2003-01-01
>>14:10 given
>>is invalid or outside the time extent defined
>>(2004-01-01/2004-02-01). </ServiceException> </ServiceExceptionReport>
>>Not sure where the image/tiff comes from.
> For WCS support, I have an OUTPUTFORMAT object defined:
> OUTPUTFORMAT
> NAME GEOTIFF_RGB
> DRIVER "GDAL/GTiff"
> MIMETYPE "image/tiff"
> IMAGEMODE RGB
> EXTENSION "tif"
> END
> ...when I commented this out, I get the error message as per above, so
> that's good.
> So why is the OUTPUTFORMAT object messing things up?
I just did a quick test on windows using latest cvs (and the
outputformat set to tiff) and I get the usual mapserv.exe download with
the exception in it. Do you get the same result for other wms
exceptions ? (the time exception is not set diffrently from other wms
excpetions)
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
