SDE raster support
    Pirmin Kalberer
    sp_ml at SOURCEPOLE.COM
    Tue Nov 16 03:28:06 EST 2004
Howard,
Am Dienstag, 16. November 2004 00.16 schrieb Howard Butler:
> Not at this time.  Also, what was checked in this afternoon doesn't seem to
> be working on my setup (ArcSDE 9.0).  It is successfully querying the
> raster stuff out of the db, as judiciously planted debug statements show,
> but it doesn't seem to be doing the drawing
> correctly.  http://mapserver.cssm.iastate.edu/foo.jpg
We were only able to test it with an SDE 8.3 server (on client side with 9.0
also). But I have installed the current CVS version in my customers
environment and they will test it with 9.0 too. If you could send me the the
debug statements, maybe I can see something.
BTW: the malloc statement you added to tpix in mapsde.c is not necessary (and
a very little memory leak).
Pirmin Kalberer
Sourcepole  -  Linux & Open Source Solutions
http://www.sourcepole.com
