Mapserver-4.4.0-beta2 jpeg legend renderi ng problem
Lars Holm Loldrup LLO at CARLBRO.DK
Thu Nov 18 11:05:08 EST 2004
Just filed a bug: http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1073
including a sample setup to reproduce the problem.
Regards Lars Loldrup.
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Thursday, November 18, 2004 3:17 PM
To: Lars Holm Loldrup
Cc: MAPSERVER-DEV at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-DEV] Mapserver-4.4.0-beta2 jpeg legend
rendering problem
Lars Holm Loldrup wrote:
> Just found a new rendering problem i 4.4 beta2: Using imageformat jpeg,
the
> legend text is distorted, but using png or gif it's fine.
> Se attached examples.
> The problem can be reproduced using the legend executable.
>  <<legend_err.jpg>>  <<legend_ok.png>>
Lars,
I did some inspection of the two result files.  If I directly translate
the good png to JPEG I get essentially the same result you saw.  It looks
like the problem is that the partial edge pixels of the text are drawn in
pure black but with reduced alpha to get the antialiasing effect.
However, when an RGBA image is saved in JPEG the alpha is just discarded
and the text edge pixels come out pure black resulting in very blocky text.
In some cases it is nearly unreadable text.
This likely depends on particular combinations of rendering options.  Could
you submit a bugzilla report with a minimal .map file to demonstrate the
problem?  Also, you can add my previous paragraph and if you wish you can
assign it directly to me.
Also, in the report please note if there is a previous version of the
software where the same test case seems to work properly.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
