SLD TextSymbolizer issue
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Fri Nov 19 12:19:27 EST 2004
We've been doing some testing of MapServer with SLD for labelling layers
and have seem to run into issues. Orginally, we had issues with
specifying fonts, however, upon deeper investigation, the problem may be
elsewhere.
Use case:
Here's a GetMap on a simple layer:
http://devgeo.cciw.ca/cgi-bin/mapserv/ecows?SERVICE=WMS&VERSION=1.1.1&RE
QUEST=GetMap&SRS=EPSG%3A4326&BBOX=-102.9742339843798,32.85352653562978,-
58.474233982194,60.66602653699591&WIDTH=560&HEIGHT=350&LAYERS=obs&STYLES
=&FORMAT=image%2Fpng&BGCOLOR=0xFFFFFF&TRANSPARENT=FALSE&EXCEPTIONS=appli
cation/vnd.ogc.se_xml&
Here's the same GetMap with an SLD:
http://devgeo.cciw.ca/ms_tmp/obs1.sld
..which was copied from the example at:
http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_tex
t_annotation.xml
..and tweaked for the layer on my server:
cation/vnd.ogc.se_xml&SLD=http://devgeo.cciw.ca/ms_tmp/obs1.sld
..which gives us back what we are expecting. However, this is not a
valid SLD document. When I create a valid SLD document:
http://devgeo.cciw.ca/ms_tmp/obs2.sld
And run the same GetMap with this SLD:
cation/vnd.ogc.se_xml&SLD=http://devgeo.cciw.ca/ms_tmp/obs2.sld
I get an Exception to the effect of:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengeospatial.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
msDrawMap(): Image handling error. Failed to draw layer named
'obs'.
msDBFGetItemIndex(): DBASE file error. Item 'PropertyName' not
found.
</ServiceException>
</ServiceExceptionReport>
In addition, GetLegendGraphic requests do not work (for any
TextSymbolizer types, actually).
Looking at the two SLD documents in question, the working SLD (which is
not valid) looks for the label property as:
/StyledLayerDescriptor/NamedLayer/UserStyle/FeatureTypeStyle/TextSymboli
zer/Label
Whereas the spec defines it like:
zer/Label/ogc:PropertyName
Comments?
..Tom
