SLD TextSymbolizer issue
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Fri Nov 19 14:37:52 EST 2004
I filed a bug on it (Bug 1076) to support both ways. Should not be
difficult to do but I have set it to be done after the 4.4 release.
Later,
Kralidis,Tom [Burlington] wrote:
>>-----Original Message-----
>>From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
>>Sent: Friday, 19 November, 2004 14:11
>>To: Kralidis,Tom [Burlington]
>>Cc: MAPSERVER-DEV at LISTS.UMN.EDU
>>Subject: Re: [UMN_MAPSERVER-DEV] SLD TextSymbolizer issue
>>Tom,
>>  Here is my understanding of the specs concerning the
>>sld:ParameterValueType" (which is taken form the sld 1.0 doc
>>section 11.1.3)
>><xs:element name="CssParameter"
>>type="sld:ParameterValueType"/> <xs:complexType
>>name="ParameterValueType" mixed="true"> <xs:choice
>>minOccurs="0" maxOccurs="unbounded"> <xs:element
>>ref="ogc:expression"/> </xs:choice> </xs:complexType>
>>The parameter values are allowed to be complex expressions
>>for maximum
>>flexibility.
>>The 'mixed="true"' definition means that regular text may be mixed in
>>with various sub-expressions, implying a text-substitution model for
>>parameter values. Numeric and character-string data types are not
>>distinguished, which may cause some complications.
>>Here are some usage examples:
>><CssParameter name="stroke-width">3</CssParameter>
>><ogc:Literal>3</ogc:Literal>
>></CssParameter>
>><ogc:Add>
>><ogc:PropertyName>A</ogc:PropertyName>
>><ogc:Literal>2</ogc:Literal>
>></ogc:Add>
>></CssParameter>
>><Label>This is city "<ogc:PropertyName>NAME</ogc:PropertyName>"
>>of state <ogc:PropertyName>STATE</ogc:PropertyName></Label>
>>I think supporting <Label>label_value</Label> should be valid. I
>>downladed your sld file and fter adding the schemas at the
>>top, It did
>>valiadte using xml-spy. Does It make sense ?
>>(Note that I initially was supporting  the label inside a
>>propertyName
>>and the code is still there but commented out).
> I retried this with just:
> <Label>OBSDATE</Label>
> ..and it validated.
> So both constructs are valid; should we support both when ingesting SLD
> XML, and output one style when producing?
> ..Tom
>>Looking into the GetLegndGraphics : I do not really
>>understand when you
>>say "for any TextSymbolizer types". Normally any sld passed
>>to the wms
>>(GetMap or GetLegendGraphic) ends up creating mapserver classes (both
>>request use the same sld parsing function), so If and sld is
>>applied and
>>the classes are created for GetMap, there is no reason that these
>>classes would not be created when doing a GetLegendGraphic.  I think
>>from your SLD, the elements <Name> is missing from the
>><Rule>, which is
>>supposed to be used as the class name. Could it be the reason ?
> I inserted <Rule><Name> and it worked -- thanks.
>>Later,
>>>Hi,
>>>We've been doing some testing of MapServer with SLD for labelling
>>>layers and have seem to run into issues.  Orginally, we had issues
>>>with specifying fonts, however, upon deeper investigation,
>>the problem
>>>may be elsewhere.
>>>Use case:
>>>Here's a GetMap on a simple layer:
>>http://devgeo.cciw.ca/cgi-bin/mapserv/ecows?SERVICE=WMS&VERSION=1.1.1&
>>>RE
>>QUEST=GetMap&SRS=EPSG%3A4326&BBOX=-102.9742339843798,32.853526
>>53562978,-
>>58.474233982194,60.66602653699591&WIDTH=560&HEIGHT=350&LAYERS=
>>obs&STYLES
>>=&FORMAT=image%2Fpng&BGCOLOR=0xFFFFFF&TRANSPARENT=FALSE&EXCEPT
>>IONS=appli
>>>cation/vnd.ogc.se_xml&
>>>Here's the same GetMap with an SLD:
>>>http://devgeo.cciw.ca/ms_tmp/obs1.sld
>>>..which was copied from the example at:
>>http://www2.dmsolutions.ca/msapps/world_testdata/tests/sld_tests/sld_t
>>>ex
>>>t_annotation.xml
>>>..and tweaked for the layer on my server:
>>>RE
>>53562978,-
>>obs&STYLES
>>IONS=appli
>>>cation/vnd.ogc.se_xml&SLD=http://devgeo.cciw.ca/ms_tmp/obs1.sld
>>>..which gives us back what we are expecting.  However, this
>>is not a
>>>valid SLD document.  When I create a valid SLD document:
>>>http://devgeo.cciw.ca/ms_tmp/obs2.sld
>>>And run the same GetMap with this SLD:
>>>RE
>>53562978,-
>>obs&STYLES
>>IONS=appli
>>>cation/vnd.ogc.se_xml&SLD=http://devgeo.cciw.ca/ms_tmp/obs2.sld
>>>I get an Exception to the effect of:
>>><?xml version='1.0' encoding="ISO-8859-1" standalone="no"
>>?> <!DOCTYPE
>>>ServiceExceptionReport SYSTEM
>>>"http://schemas.opengeospatial.net/wms/1.1.1/exception_1_1_1.dtd">
>>><ServiceExceptionReport version="1.1.1">
>>><ServiceException>
>>>msDrawMap(): Image handling error. Failed to draw layer named
>>>&#39;obs&#39;.
>>>msDBFGetItemIndex(): DBASE file error. Item
>>&#39;PropertyName&#39; not
>>>found. </ServiceException>
>>></ServiceExceptionReport>
>>>In addition, GetLegendGraphic requests do not work (for any
>>>TextSymbolizer types, actually).
>>>Looking at the two SLD documents in question, the working
>>SLD (which
>>>is not valid) looks for the label property as:
>>/StyledLayerDescriptor/NamedLayer/UserStyle/FeatureTypeStyle/TextSymbo
>>>li
>>>zer/Label
>>>Whereas the spec defines it like:
>>>li
>>>zer/Label/ogc:PropertyName
>>>Comments?
>>>..Tom
>>Assefa Yewondwossen
>>Software Analyst
>>Email: assefa at dmsolutions.ca
>>http://www.dmsolutions.ca/
>>Phone: (613) 565-5056 (ext 14)
>>Fax:   (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax:   (613) 565-0925
