Handling special characters
Palanisamy, Giri palanisamyg at ORNL.GOV
Fri Nov 19 16:01:23 EST 2004
The numbers (ñ) also just displayed as numbers, didn't convert it to special characters!
-----Original Message-----
From: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On Behalf Of Daniel Morissette
Sent: Friday, November 19, 2004 3:55 PM
To: MAPSERVER-DEV at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-DEV] Handling special characters
Palanisamy, Giri wrote:
> I have also tried adding the special characters directly in to the dbf file (edited in excel) ie directly added "La Cigüeña", but my mapserver application displayed as "La Cige¤a".
I'm not sure why the entities conversion doesn't work for you, but using
the numerical value might work.
For "ñ", use "ñ"
For the complete list, see
http://www.w3.org/TR/REC-html40/sgml/entities.html
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
