[Mapserver-dev] mapindex.c
Steve Lime steve.lime at dnr.state.mn.us
Fri Oct 1 00:50:00 EDT 2004
That was an index format I used between the rtree support I had
originally
added and the quadtree support. It can be safely removed.
Steve
>>> Frank Warmerdam <warmerdam at pobox.com> 09/26/04 8:34 PM >>>
Folks,
What is the code in mapindex.c for?  From a review, I get the impression
it
is some sort of spatial indexing for shapefiles based on a fixed grid
size
(as opposed to the quadtree approach of maptree.c).  Is it still used?
If
not should it be removed from the tree?
I am implementing more complete support quadtrees for spatial searches
in
shapelib, and will use the "new" .qix format for compatibility with
mapserver.
I will be incorporating support for this into OGR so I can have spatial
searches
in OGR nearly as fast as MapServer.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
Mapserver-dev mailing list
Mapserver-dev at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-dev
