[Mapserver-dev] mapserv43 bug in getCapabilities document ?
Astrid Emde
astrid.emde at ccgis.de
Fri Oct 1 11:33:58 EDT 2004
This is a multi-part message in MIME format.
--------------030903070607090109040908
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 8bit
Hello,
we have a problem with the new mapserv 4.3
The getCapabilities-Dokument has a bug in the <Forrmat>-Tag.
Try the following URL...
http://wms1.ccgis.de/cgi-bin/mapserv43?map=/data/umn/alk_zv_aut_14/alk_edbs_011_ms43.map&request=capabilities&wmtver=1.0.0
The format-Part doesn't come back properly in tags.
<Format><MIME /><GML.1 /></Format>
So the client can't read out the Format-tags.
I hope you can understand what I mean. Does anyone has an idea?
Astrid
Astrid Emde
CCGIS GbR
Siemensstraße 8
53121 Bonn
Germany
www.ccgis.de
Tel.: ++49 (0) 228 90826 19
Fax.: ++49 (0) 228 90826 11
Zentrale: ++49 (0) 228 90826 0
Content-Type: text/xml;
name="alk_edbs_011_ms43.xml"
Content-Transfer-Encoding: 7bit
Content-Disposition: inline;
filename="alk_edbs_011_ms43.xml"
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://www.digitalearth.gov/wmt/xml/capabilities_1_0_0.dtd"
<!ELEMENT VendorSpecificCapabilities EMPTY>
]> <!-- end of DOCTYPE declaration -->
<WMT_MS_Capabilities version="1.0.0">
<!-- MapServer version 4.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
<Service>
<Name>GetMap</Name>
<Title>ALK_f011</Title>
<Abstract>ALK Gebaeudeflaechen</Abstract>
<OnlineResource>http://wms1.ccgis.de/cgi-bin/mapserv43?map=/data/umn/alk_zv_aut_14/alk_edbs_011_ms43.map&</OnlineResource>
<AccessConstraints>none</AccessConstraints>
</Service>
<Capability>
<Request>
<Map>
<Format><GIF /><PNG /><JPEG /><WBMP /></Format>
<DCPType>
<HTTP>
<Get onlineResource="http://wms1.ccgis.de/cgi-bin/mapserv43?map=/data/umn/alk_zv_aut_14/alk_edbs_011_ms43.map&" />
<Post onlineResource="http://wms1.ccgis.de/cgi-bin/mapserv43?map=/data/umn/alk_zv_aut_14/alk_edbs_011_ms43.map&" />
</HTTP>
</DCPType>
</Map>
<Capabilities>
<Format><WMS_XML /></Format>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</Capabilities>
<FeatureInfo>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</FeatureInfo>
</Request>
<Exception>
<Format><BLANK /><INIMAGE /><WMS_XML /></Format>
</Exception>
<VendorSpecificCapabilities />
<UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>
<Layer>
<Name>alk_011</Name>
<SRS>epsg:31466</SRS>
<LatLonBoundingBox minx="6.25808" miny="51.3128" maxx="6.27316" maxy="51.32" />
<BoundingBox SRS="EPSG:31466"
minx="2.51799e+06" miny="5.68634e+06" maxx="2.51904e+06" maxy="5.68714e+06" />
<ScaleHint min="0" max="24.9451" />
<Layer queryable="0">
<Name>f011_e_fla_Gebaeude</Name>
<Title>011_e_fla</Title>
<LatLonBoundingBox minx="-180" miny="-3.40166e+32" maxx="174.615" maxy="3.40166e+32" />
minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07" maxy="2.5e+07" />
<ScaleHint min="0" max="2.49451" />
</Layer>
<Name>f011_a_lin_Gebaeude</Name>
<Title>011_a_lin</Title>
</Layer>
<Name>f011_a_sym</Name>
<Title>011_a_sym</Title>
<ScaleHint min="0" max="4.98903" />
</Layer>
<Name>f011_t_pkt_a_Hausnummern</Name>
<Title>011_t_pkt</Title>
</Layer>
</Layer>
</Capability>
</WMT_MS_Capabilities>
--------------030903070607090109040908--
