[Mapserver-dev] SDE Connection Pooling
Howard Butler hobu at iastate.edu
Fri Oct 1 19:06:01 EDT 2004
Folks,
I have updated mapsde.c to use Frank's new connection pooling API.  This
new approach cleans up the connection sharing a lot, and hopefully this
will be end the freeing of invalid connections by SDE.
To make this change, I had to change the syntax of how SDE versions are
specified.  In the past, we had been specifying them on the CONNECTION
string like this:
CONNECTION "sdemachine.iastate.edu,port:5151,sde,username,password,SDE.DEFAULT"
The problem with this is that once we start sharing connections, even
though we specify the same version *name* for a layer, the name points to
different version states for different layers.  Versions in SDE are done
with something called state_ids, and two layers with the same version name
could be at two different state_ids.  A version is really the property of a
layer, IMO, not the connection.  Migrating SDE's connection sharing
approach to the connection pooling API made this much clearer for me, and I
regret that I hung it off of the CONNECTION string in the past.
So now (in CVS and soon to be 4.4), to specify a version for a layer, you
do it on as the last parameter of the DATA string like this:
DATA "HOBU.mylayer,shape,SDE.DEFAULT"
As before, if you do not specify a version, the default version will be
used.  This means that if you weren't monkeying around with specifying your
versions in SDE layers before, nothing should have changed at all.  If you
were using versions, you'll have to move the version name in layer from the
end of the CONNECTION string to the end of the DATA string.
Howard
