[Mapserver-dev] compile error
Daniel Morissette
dmorissette at dmsolutions.ca
Mon Oct 4 12:09:47 EDT 2004
Kralidis,Tom [Burlington] wrote:
>>>: undefined reference to `msConnPoolRelease'
>>>collect2: ld returned 1 exit status
>>>make: *** [shp2img] Error 1
>>Tom,
>>Try re-running config.status. This will regenerate your
>>Makefile from Makefile.in using your last configure options.
>>Two new files were added to Makefile.in.
> This worked -- thanks.
Tom, and all,
Unless you know for sure that there was no significant change, you
should always rerun configure and do a "make clean;make" after updating
from CVS. Even if the build appears to have worked, if you don't do a
"make clean" you could have surprises at runtime.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
