[Mapserver-dev] IGNORE_MISSING_DATA - make this dynamic?
Sean Gillies
sgillies at frii.com
Wed Oct 20 17:09:36 EDT 2004
On Oct 20, 2004, at 2:26 PM, Frank Warmerdam wrote:
> Folks,
> Currently we have a macro called IGNORE_MISSING_DATA that if defined
> causes MapServer to quietly proceed if some raster files or shapefiles
> are
> not found that are expected (such as those from a tileindex, or the
> main
> DATA file for a layer). It would appear, at least on Unix, that this
> symbol
> is normally defined meaning that most mapserver binaries are very
> forgiving
> (but not terribly informative) about layers with missing files.
> I feel that having it as a compile time directive makes it harder for
> folks
> who just receive binaries to control this behaviour. Also, having it
> turned on by default makes it harder for folks to debug problems in
> their
> maps as they work.
> I would like to suggest getting rid of the macro, and instead having a
> layer or map level directive (via PROCESSING or CONFIG) to control this
> dynamically. Furthermore, I would like the default be to error-out on
> missing data, so the user who anticipates this happening sometimes
> would
> have to add the directive to get the more forgiving behaviour.
> Any thoughts on this? Is this a feature that should be put off till
> after
> the 4.4 release? Should I just forget the idea?
> Best regards,
Frank,
I'd be OK with this. My preference is for MapServer to set an error,
and
that this error be handled either by the programmer (in the mapscript
case)
or (in the CGI case) by blocks of code indicated by processing or config
directives.
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
